Meth Injection
Meth Injection
with the byt meth throttle body spacer coming soon there will be a lot of us looking for meth kits. so what kit to go with and why? snow, devils own, aem, ais?????
I like the boost reference set up vs. wiring into the MAP or MAF sensor.
If you contact Devils own, they will talk you through the different kits.
I'm sure other vendors do the same.
aem has a 5 gal tank too....just don't know where to mount that bish in my hhr without totally screwing cargo space....wonder if it would fit in the spare tire well. either way my tank is getting mounted in the back...no room under our hoods.
anything in particular that makes the ais kit stand out?
I feel that they are all fairly comparable in price...ranging from around 350-450. I just want to get whatever is best here....i don't want my car to go boom again....especially since this would be my fault
again why is ais the /thread kit???
I just got the Devils Own progerssive stage 2 kit and the 2.5 gallon sump tank. I have it installed but i'm not tuned yet. Hookup was super easy and I like that I just tap into a vacum line, no cutting into anything. I got the kit and the tank shipped for less than what the kit shipped would cost so it was an easy choice....pm and i'll give you the dudes number.
Didn't put the front bracket on yet, screw would go through the spare tire so I gotta figure something out still.
I don't recommend a Stage 1 kit for a daily driver car with stock turbo. Just my personal preference. I run the Stg1 on my drag car but only because I either drive easy and normal or racing. So I set it to come on at 20psi and tuned accordingly.
I wouldn't want to run any meth unless I was getting on it though.
With a turbo progressive controller is beneficial, blower is either on or off so hobbs switch is fine. and i say ais because all of their kits components are top notch and customer service is second to none
thanks...i know i definitely want a progressive controller....other than that i don't really know what separates the kits from each other. are there features that ais has that the other kits may not???
I run the progressive AEM kit from Modern Performance. I love it. Progressive is the way to go on a daily car. I have mine set to start the spray at 10psi, then full by about 17-18. This allows full spray at WOT 24psi then if the boost tapers below 18 it starts to slow the flow of meth. What sucks about our cars is that we have no lag time so the kit is pretty on of off when it comes to progressivly enabling it. only time it does work progressive is when i roll into the throttle
Im looking for a kit that doesnt have the tank, Car isnt driven in winter or rainy days and is stored in a garage, Would just like to use my windsheild washer tank instead of installing a new tank. Anyone have suggestions?
Devils Own make a kit with a tank tap for your existing windshield washer bottle
the quality of the parts and ais' new pumps can handle 100% meth where the competition says they can but wont. their check valves are made better which is one of the most important failsafes of the system, and their tanks are alot better looking then some of their competitors in my eyes
Theres only a handful of meth kits I would ever run 100% Meth injection with and they aren't cheap.
If you decide to run 100% Meth and your fail safe doesn't work, BOOM!
My suggestion to you people wanting to run Meth injections is to call different vendors, get info and do your research.
Don't depend on joe blows word because hes ran x kit and has had luck with it.
If you want high quality, Aquamist is a great product.
With Methanol Injection kits, you pretty much get what you pay for.
