Meth Injection
Old Sep 4, 2011 | 07:41 PM
  #51
dayhoff35's Avatar
Ok stupid ? But Rhys just the 50/50 mix coolant you get at the stores right
Old Sep 4, 2011 | 08:11 PM
  #52
CTFinestTurbo's Avatar
wut do you mean?
Old Sep 4, 2011 | 08:25 PM
  #53
dayhoff35's Avatar
For the 50/50 spray or atleast I think that's what someone told me
Old Sep 4, 2011 | 08:26 PM
  #54
not understanding lol you want to buy 50/50 coolant to spray in your engine?
Old Sep 4, 2011 | 08:40 PM
  #55
dayhoff35's Avatar
Yeah someone told me that's what you can use instead of spraying straight meth I don't know anything about it though
Old Sep 4, 2011 | 09:01 PM
  #56
peoples use windshield washer fluid mixed with meth or boost juice wut i will be running in my car since its already 50/50 mix
Old Sep 4, 2011 | 09:05 PM
  #57
BIG SS TC's Avatar
is their a how to for it
Old Sep 4, 2011 | 09:12 PM
  #58
dayhoff35's Avatar
Oh ok that's what I ment what's the benefits and drawbacks or meth compared to the 50/50
Old Sep 4, 2011 | 09:28 PM
  #59
Iam Broke's Avatar
Don't spray 100% meth, it's flammable at that concentration. Nasty engine fires can result on a backfire.
Boost Juice is 49% meth IIRC.
-20* Wal Mart washer fluid is ~33% meth, (PEAK brand or Super Tech) a good place to start IMO, if you want 50%, buy the boost juice or take a gallon jug, add 3) 12 oz bottles of HEET (100% meth) and fill the rest with -20* WWF.
Go to the Wal-Mart site and serch the MSDS sheets on WWF, it shows the approx meth content of each. Stay away from anything with soaps in it. (Bug off, ect)
Old Sep 4, 2011 | 09:40 PM
  #60
Frogstofall's Avatar
Unless I'm misunderstanding you, this would put you OVER 50% MeOH right?
I would assume 5 x 12 oz bottles of HEET and the rest R.O. Water would be what you're after...
Old Sep 4, 2011 | 09:54 PM
  #61
dayhoff35's Avatar
Where can you get heet it boost juice, just online?
Old Sep 4, 2011 | 09:57 PM
  #62
I see HEET at Autozone and other auto parts places during the winter months. I'm sure you can get it online.
  #63
bamaboy22's Avatar
**** I see it year round here at places
Old Sep 4, 2011 | 09:59 PM
  #64
bamaboy22's Avatar
This is what your talking about right
HEET Gas-Line Antifreeze and Water Remover - Auto Pros
  #65
dayhoff35's Avatar
Ok just wanted to make sure might have to go pick some up soon thanks guys
Old Sep 4, 2011 | 10:04 PM
  #66
dayhoff35's Avatar
Tom would straight peak which is 33% be ok to spray alone for a little while?
Old Sep 4, 2011 | 10:53 PM
  #67
Iam Broke's Avatar
Yes. That's what I started out with.
I remember reading 36 oz of HEET and 82 oz of -20* WWF would put you at 50% meth.
I just did some quick calculations with 82 oz of 33% WWF+ 36 oz of HEET and came up with 49.2% meth.
Old Sep 4, 2011 | 10:55 PM
  #68
instead of goin thru all the trouble to get the right mix ill jus spend $5 a gallon for boost juice.
Old Sep 4, 2011 | 11:11 PM
  #69
dayhoff35's Avatar
yeah thats probably what ill do not that bad of a price either.
Snow Performance: Boost Juice?
Old Sep 4, 2011 | 11:16 PM
  #70
yea and that will last you for a while unless ur spraying alll the time
Old Sep 4, 2011 | 11:26 PM
  #71
dayhoff35's Avatar
yeah im about to order it actually
Old Sep 5, 2011 | 12:04 AM
  #72
I think you meant 92 oz. of WWF. I think I see it now.
I am curious about the dyes though. I intend to use pure MeoH and R.O. Water when i get my setup. Is it possible these dyes can build up over time and cause problems at all? I've seen pics of the inside of manifolds where people used Peak or similar things and it's coated blue. Makes me curious...
Old Sep 5, 2011 | 10:58 AM
  #73
Iam Broke's Avatar
Yeah, I was tired and figured it wrong on the total last night. I did mean to use 92 oz. WWF with 32 oz HEET but that comes out to 52% with 33% meth WWF, slightly flammable on it's own.
If you start with 30% methanol WWF, it's 46.5% by volume.
Yes the blue dye can build up a film over time, I don't know if it matters or not. (Look at the carbon buildup on the valves) Boost Juice is dyed red.
Spraying meth in the intake will help clean the valves at any rate.
Old Sep 5, 2011 | 11:44 AM
  #74
zrated89's Avatar
i use M1 5 gallon drums of meth with a distilled water 50/50 mix. I then add a bit of food coloring to the mix to be able to see it better in the line. ive never seen a color build up on my intake or blower and i spray pre blower via throttle body spacer. But the dye in washer fluid is alot darker than my few drops of food coloring
Old Sep 5, 2011 | 01:30 PM
  #75
bucks121's Avatar
i live in canada and no one ships boost juice or w/e to canada what can i do?
