Meth install problems.. before and after
Old Aug 5, 2010 | 03:58 PM
  #51
smthomas556's Avatar
Originally Posted by Terminator2
It can be done but the ECM does fight with you. I wish I could change the OL/CL settings but alas HP Tuners is way behind on the LNF ECM.
Hows Nick's car coming Term?
Old Aug 5, 2010 | 04:06 PM
  #52
Terminator2's Avatar
Pretty good. It still does not like timing at all for some reason. I guess the 91 octane you guys have is pretty bad because he was knocking on 10* of peak timing 5* in the midrange on just gas. He is running almost twice as much timing on the meth with minimal knock on the last log.
Old Aug 5, 2010 | 04:08 PM
  #53
Yeah gas sucks out here. My car still had tip in on 91 and meth. Thats why I went E85. Too bad he cant.
Old Aug 5, 2010 | 04:16 PM
  #54
I did not know you guys had E-85 out there. He can use a mix of E-85 and gasoline. He can use up to 2 parts E-85 to one part E-10. The LNF can handle up to at least 60% ethanol without surpassing the injection window.
Old Aug 5, 2010 | 04:19 PM
  #55
Yeah myself and SCcobaltSS ( Chris ) are running E out here. HUGE difference. Ill let him know about blending.
Old Aug 5, 2010 | 04:39 PM
  #56
If I knew you guys had E-85 out there I would have told him not to bother with the meth kit. Although, I bet his intake valves are getting nice and clean now and it does seem to help the performance some but not until the meth starts injecting.
Old Aug 5, 2010 | 04:46 PM
  #57
That was my problem with meth. I had horrible tip in during daily driving. I could not even pass someone on the freeway at partial boost without knock. WOT was fine. Its too hot out here. Thats the main problem.
  #58
ei3dag3's Avatar
Originally Posted by pookie025
just normal -20 auto zone ****. i read some where that normal -20 is 30% meth and 70% water. then you need to add four qts of heet to make it 50/50.. but im only running 30/70
i thought every bottle of heet you add to the gallon mixture of -20 is an extra 10%?
thats what i was told from alcohol systems. maybe i just forgot.
Old Aug 5, 2010 | 04:47 PM
  #59
09PitchBlackSS's Avatar
Pics of the diaphragm? Where is it torn?
Old Aug 5, 2010 | 05:11 PM
  #60
Wangspeed's Avatar
Heet is over 99% methanol. It's almost straight meth. If you do the math, adding it to standard WWF, you need 3 bottles to reach 50/50.
It's actually kind of convenient to have the blue dye in there. It'll make it VERY obvious if you have a leak in the system anywhere in the engine bay.
I agree with the person above that you really shouldn't be messing with meth if you haven't done the research. It can be an awesome way to gain power and cool down the engine, but if you don't know what you're doing, it's a recipe for disaster down the road.
Here's an Excel spreadsheet that will help you calculate WWF/heet combinations. Click on the "Super Blue" entry. What you want to use is -20F WWF. The labelling requires that they have volatile content by %. Pick up a container and read the label. It'll say 35% by weight on a -20F jug. Shake it and make sure it does not foam up (detergents). The cheaper the better. This guy's spreadsheet even has various brands in it.
Anyone that tells you not to run WWF simply doesn't understand what they're doing, and so they follow someone else. Buying pre-mixed 50/50 over the internet is kind of ridiculous.
bcBlues Methanol Mixing Spreadsheet
Old Aug 5, 2010 | 05:55 PM
  #61
09CobaltSS1's Avatar
Originally Posted by BYT*SS*TURBO
Id prefer you didn't post logs of my tunes thanks lol..
And the BPV tear is an obvious problem, I don't know why you keep trying to race people with a broken car lol. Fix it, we'll meet up and check the tune and you'll be good to go.
Nick sorry if that came across the wrong way. I wasn't planning on posting any maps or anything really in depth. Just a screen shot of a basic log graph for Pat to look at. Anything more in depth (timing curves, waste gate %'s, loads, ect ect) I would take off of the graph for the screen shot. I'm not exactly sure what he would need me to post them for when he could just view my logs in person or better yet, ask you. I had no intentions of divulging any BYT secrets.. I'm not lookin to **** you off or screw you man. I can assure you that..
Old Aug 5, 2010 | 06:16 PM
  #62
Jmoney's Avatar
what do u mean uget "tip in" during daily driving. sorry if i sound dumb.
Old Aug 5, 2010 | 08:18 PM
  #63
Its when your car knocks the moment before you go wide open throttle.
Old Aug 5, 2010 | 08:26 PM
  #64
pookie025's Avatar
http://www.greedspeed.com/applicatio...T_Bypass_Valve
http://shop.achtuning.com/bosch-moto...ter-valve.aspx
would these work for the bpv?
Old Aug 5, 2010 | 08:28 PM
  #65
Wangspeed's Avatar
Not even close. It's built into the K04 turbo. Does anyone even sell a rebuild kit for our built in BPV?
Old Aug 5, 2010 | 08:31 PM
  #66
pookie025's Avatar
http://www.importevolution.com/produ...oducts_id=2926
this looks more like it?
Old Aug 5, 2010 | 08:40 PM
  #67
sorry man... that won't work either
Old Aug 6, 2010 | 07:53 AM
  #68
iboost's Avatar
I think GMpartsdirect you can get the "whole" bypass valve. Its like $60 bucks and I believe it comes with the tan cover thing, the spring and the diaphragm. I just need a diaphragm and I think I'ma have to spend the money for all of it
Old Aug 6, 2010 | 08:10 AM
  #69
I think pookie looked into that already and found that they were on a national back order. I could be wrong but I'm pretty sure that's what he said he found out. I'm not sure if there was even a time frame given on when the back orders could be fullfilled. It definitely sucks because this could potentially happen to anyone really
Old Aug 6, 2010 | 08:20 AM
  #70
iboost's Avatar
yea I have a small tear in mine right now. I really didn't wanna pay $60 for that diaphragm...but I think I might have too...
Old Aug 6, 2010 | 11:24 AM
  #71
pookie025's Avatar
i dont care ill pay the money... gotta pay to play...
Old Aug 6, 2010 | 12:19 PM
  #72
Whitty's Avatar
someone mentioned in another thread that the diaphram is on national back order that was just a few days ago forget the thread, i think it was 1 of the many GMS1 problem threads.
Old Aug 6, 2010 | 12:55 PM
  #73
pookie025's Avatar
i had ordered it back in march and 2 months later it was ready to ship and i never got it!!!!
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
