Meth killed my engine.
Old Jun 15, 2012 | 12:30 PM
  #101
ei3dag3's Avatar
this thread made my brain hurt.
Old Jun 15, 2012 | 07:17 PM
  #102
tomj77's Avatar
Originally Posted by Balt_and_Vette
Royal Purple is garbage oil. It does what is says with the added horsepower and fuel economy but that because it runs like water when its hot. Once it gets hot it's no good. Run it in a b series honda and you will literally have no oil left after 1000km. I run 10-40 amsoil right now and my car loves it. I get no blow by any more which was causing my mil to come on because of oil on my map sensors. Amsopil is by far the best oil. If you want to save some money go with Penzoil platinum which is also a terrific oil.
ya i did alot of checking on other forums and reviews of the stuff and this is exactly what i read from many many people. and alot of people were saying when they put it in, their cams started ticking....due to no lubrication im guessing, then they drained it and went back to mobile 1 and it stopped, unfortunitly for me, i waited to long and the one cam lobe was destroyed and wrecked the rest of the engine with the filings. Id advice everyone to stay away from it. its made for race cars that change their oil after every race, they never changed the formula for street cars, same ****, it will work fine in na cars when u drive nicely, but not for performance cars, if anyone runs it with no issues, consider urself lucky and change it, and maybe take off valve cover and have a look, i did notice all my lash ajusters had scrach marks on them.
Old Jun 15, 2012 | 07:55 PM
  #103
soundjunky's Avatar
hmm, I take it that this means you've come to a new conclusion about the real culprit here huh?
Someone should sue royal purple for not living up to their claims
Old Jun 15, 2012 | 08:00 PM
  #104
Edubs's Avatar
I run 10-40 also (total seal rings). Brad Penn, though...
Old Jun 16, 2012 | 12:09 AM
  #105
tomj77's Avatar
no, this was my conclution the whole time if u read my posts. the Meth killed it was Gm reginal service managers conclution once my old dealer told him i used to have the kit. im trying to talk directly with gm now about it, doesnt hurt to try right.
Old Jun 16, 2012 | 01:24 AM
  #106
soundjunky's Avatar
that make a WHOLE lot more sense.
good luck!!
Old Jun 20, 2012 | 09:05 AM
  #107
USMCFieldMP's Avatar
Rattlesnake Race Shop
I'm willing to bet that your problem wasn't what oil you were running... but how much oil you were running.
I run 4.7 liters of oil like the books says, so no, that's not it.
That might be how much you put into it... but how often did you check your oil level? I check my oil every other, if not every, gas fill up. The one time I was running RP was the only time I've ever had to add oil in between oil drains. I run Amsoil exclusively in all my cars now.
Old Jun 20, 2012 | 09:35 AM
  #108
tomj77's Avatar
Honestly not often, but when I drain it I always have the same amount as I put in, I pour it in old jugs and I get the same amount I had in. And when I rp I had it in for a month before I drained it so it was all there as well. By ya I do check from time to time and it's always good.
Old Jun 20, 2012 | 05:52 PM
  #109
sebleroux08/tc's Avatar
What is your thought on amsoil? I've been running it for 5k km and I just did my oil change and it was perfect didn't even change shades. I have always ran it in my snowmobile but first time in my car
Old Sep 20, 2012 | 11:55 PM
  #110
Late response... but I haven't visited this shithole in a while.
I love Amsoil. If you're only running it for 5,000km, you're wasting it. I run it for 10,000 MILES in my Volkswagen VR6. Drain it, send a sample to Blackstone Labs, and usually get a response back that it still has plenty of life left, filtration looks good, the additive levels are good, and that I can try 13,000 miles the next time if I want. A quality oil filter is absolutely imperative. The nice thing about the Cobalt, of course, is that you can change your oil filter halfway through.
In my Cobalt, I never did 10,000 miles... most I ever did was 7,500 to 8,000 miles. Once I put the built motor in the Cobalt, I'll probably work my way up to 10,000 miles. 5, 7.5, then 10. I highly recommend using Blackstone Labs Oil Analysis to have your oil checked.
Old Sep 21, 2012 | 08:18 AM
  #111
user 72239's Avatar
I'm going to be sending in a sample to them here in a few days cause im due for an oil change.
Old Sep 21, 2012 | 09:44 AM
  #112
I've got one sitting on my workbench that I need to send in.
Old Sep 21, 2012 | 09:49 AM
  #113
68nova200's Avatar
How much does that oil testing cost? And what filter would be best for running with the amsoil?
Old Sep 21, 2012 | 10:02 AM
  #114
MyOtherSS's Avatar
Originally Posted by Stamina
I blew my engine within the first hundred miles of switching to Royal Purple. The piston almost looked like it got some sort of oil detonation going in between the rings. It blew a hole straight through the side, to the inner oil passage of the piston.
I know a local drag racer blew his 9 second motor with 2runs after switching to that ****.
Old Sep 21, 2012 | 10:10 AM
  #115
I think the testing is like $25, but it's been a while since I've done one. The AC Delco filters that you can get from CED are perfect. Mann-Filter makes one, as well - part number ML-1015. I've never used Mann on my Cobalt, but that is what I use in both of my Volkswagens and they have performed flawlessly, so I'd expect nothing different out of their Cobalt filter. It's probably what I'll end up using now, actually.
Old Sep 21, 2012 | 10:12 AM
  #116
68nova200's Avatar
OK i have been thinking about switching to amsoil in all my vehicles because of the long interval between oil changes.
Old Sep 21, 2012 | 03:14 PM
  #117
Stamina's Avatar
I've run Amsoil on my sportbike for its whole life so far (20,000+ miles) and have been quite impressed by it so far. The oil seems to be quite resilient and doesn't break down that quickly at all.
I hesitate to run something different [than Mobil 1] on my car though, following the Royal Purple catastrophe and since I've got more money tied up in the car, but it's been something I've considered.
Old Sep 21, 2012 | 08:52 PM
  #118
FF_ace's Avatar
im thinking of making the switch to amsoil
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
