MPX Oil Catch Can Hook Up Help
Old Jul 12, 2012 | 11:56 AM
QuickSilver_SS's Avatar
I recently got ahold of an MPX Oil Catch can. I am wondering if someone can help me figure out where to hook it up too ? I want to hook it up to try and dampen the intake valve grude issue as much as possible. But... I have no idea where and which lines to hook it up too ? Does anyone have any good pictures of there s hooked up and where on the turbo to hook it up to on an 09 ss/tc.
Thanks !
Old Jul 12, 2012 | 01:12 PM
tomj77's Avatar
U don't know what a crank case breather line is? One runs from valve cover to ur intake. The other goes from turbo to valve cover, pick one of those to, if u really wanna keep oil out, put a catch can on both lol
Old Jul 12, 2012 | 02:17 PM
Powell Race Parts's Avatar
Thats not true Tom sad to say and you can screw your system up misintalling catch cans. Good luck.
Old Jul 12, 2012 | 02:37 PM
Well which is the right line ? Any pics or help please. I don't want to screw up my car at all.
Old Jul 12, 2012 | 02:45 PM
DPveritasGold's Avatar
The correct one is the one going from your turbo to the valve cover NOT the one going to your intake. See the image shown in the forum below. It's the one highlighted in orange.
https://www.cobaltss.net/forums/2-0l...ch-can-253878/
Old Jul 12, 2012 | 03:18 PM
tomj77's Avatar
Why isn't it true? They both spray a little oil.
Old Jul 12, 2012 | 03:26 PM
Thank You !! So I hooked my catch can up from the back of my valve cover. Into my catch can. Out of the catch can and into the front of the turbo housing where the original spot where it plugged into. Does that sound right ? It seems so straight forward I'm scared I'm putting it in the wrong spots and cause my engine or turbo to blow up !
Old Jul 12, 2012 | 03:42 PM
tomj77's Avatar
If u put it in wrong spot ur engine won't blow up, Iv had mine in the other spot for the life of the car and it was just fine, half the people say one way, the other half say the other. The turbo one goes into the valve cover only, the intake one goes into a hole down inside the head somewhere, never looked where it goes
Old Jul 12, 2012 | 03:44 PM
tomj77's Avatar
Just know the turbo one is a pita to get off the valve cover, u have to cut it off with rotary tool or dremel
Old Jul 12, 2012 | 03:45 PM
Well , the other end of the catch can would have to go to the turbo ? Right ??
Old Jul 12, 2012 | 03:55 PM
Wangspeed's Avatar
That's the wrong spot.
It needs to be on the other one. The one you hooked it up to has a check valve built into it, so it shouldn't be possible for oil to get through there, unless the angle of the tube into the intake is incorrect.
Old Jul 12, 2012 | 04:05 PM
Frogstofall's Avatar
Also if you do it right, you don't have to dremel that thing off. You can use a zip tie bent into a -> "O" shape and squeez it in there (Powell's trick). I just used a flat head screw driver and bent the thing in a couple spots on the inside and it slid off with a little elbow grease.
Old Jul 12, 2012 | 08:11 PM
Well here are a few pics of how I have it hooked up and where too. I didn't have to dremel anything off. And really , it was easy ! But , is it hooked up the right way ? This first pick shows where I hooked one of the lines into that bendy part in the front of the turbo.
This second one shows where I put it into the back of the valve cover on the passanger side.
And lastly , its all done. Except for putting on the four clamps.
So does it all look right ?
Old Jul 12, 2012 | 08:48 PM
tomj77's Avatar
k whats the part number or where can i find the hose that goes from intake to valve cover?
Old Jul 12, 2012 | 08:51 PM
^^Looks right to me...
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
