my bov story
Old Mar 22, 2010 | 06:28 PM
pookie025's Avatar
my bov story
so if you have read my threads i have been going back and fourth for almost a year with compressor surge from a hks bov. i recently accuried a boost leak and the block off plate was only held on by two bolts. so i was fed up and threw on the stock bpv and hooked it up. i had a cel p2261 also. after hooking up the bpv the car sounds so much better!!!! no more surge like im feeding pegions at bk. the car used to buck and stutter at low boost... now so smooth and a nice clean smooth ride and boost @ 26 psi is holding up great. i had a leak from the block off plate and was only running 18 psi... now 26 psi nitto 555s ftw. so happy!!!!!!!!!!!
PLEASE EVERYONE DONT BUY A BOV!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 22, 2010 | 06:31 PM
HB_SS/TC's Avatar
Idk that's your problem you couldn't hook it up correctly.
Old Mar 22, 2010 | 06:47 PM
pookie025's Avatar
it was hooked up correctly. it dosent take rocket science but i guess it does with this car... any ways stock bpv is so much better. my a/f ratio isnt all out of wack now either
Old Mar 22, 2010 | 06:59 PM
BYT*SS*TURBO's Avatar
I have to agree with HB on this one. After just tuning and driving in BBG's car with the atmospheric Hahn BOV on it, no issues from it. Car still has the MAF in the stock location too. Just needs to be tuned
Old Mar 22, 2010 | 07:00 PM
pantherqs's Avatar
HKS ssqv? Did you slap some RTV around the c-clamp? If not, 100$ say's it leaked there and fucked everything up.
Old Mar 22, 2010 | 07:02 PM
TurboTechRacing's Avatar
Yes very true, as you can do 2 things if you get an aftermarket BOV.
1. make sure it is recirculated like stock, no tune is needed, but a tune is always nice to have.
or
2. get a re tune to accomidate the effects of venting to the atmosphere.
A simple re tune by BYT would have been the best bet...
Originally Posted by pantherqs
HKQ ssqv? 100$ say's you didn't slap RTV around the c-clamp and it leaked throwing everything off.
It does not take much of any leak to cause an issue with these ecu's
Last edited by TurboTechRacing; Mar 22, 2010 at 07:02 PM. Reason: Automerged Doublepost
Old Mar 22, 2010 | 07:04 PM
pantherqs's Avatar
Oh I know, took me a completely wasted weekend to figure mine out after tearing my tune down a billion times.
Old Mar 22, 2010 | 07:05 PM
Dang!
Old Mar 22, 2010 | 07:08 PM
Does it happen to be an adjustable BOV or one of the ones with the interchangeable discs? Have you tried another disc or tightened the load on the spring??
Old Mar 22, 2010 | 07:46 PM
pookie025's Avatar
wasnt adjustable version 3
Old Mar 22, 2010 | 07:53 PM
Boosted_Cobalt09's Avatar
if you tried running an atmopheric bov without recirculating it or without a maf relocation then your going to have issues. you cant tune for them without either of those mods that i listed either. that hahn bov is garbage too.
Old Mar 22, 2010 | 08:51 PM
09CobaltSS1's Avatar
BYT, last i knew i thought you and termi were pretty much in agreement that a bov was really not necessary and you guys arent interested in running one in your own cars. I mean as long as he's happy and the car is running properly is all that matters i would think. Plus a bov is really pointless with the stock turbo configuration. He really had nothing but issues with that bov right from the get-go so it seems like the most logical move for him at this point. It's all good either way, i just see no real reason to give him a hard time
Old Mar 22, 2010 | 09:15 PM
Some people like the sound. No reason you can't run one if that's what you want. I won't run it because Im cheap lol. Im into going fast for the least amount possible
Old Mar 22, 2010 | 11:54 PM
tom.g's Avatar
Out of curiosity how would you tune for a car with a BOV and MAF in the stock location? Doesn't it go pig rich after every shift?
Old Mar 23, 2010 | 12:47 AM
you can tune the car somewhat but honestly you will never be able to get rid of the rich spikes completely.
Old Mar 23, 2010 | 09:09 AM
JPizzle's Avatar
Yep!
or
Yep! X2
I have no issues.
Old Mar 23, 2010 | 09:18 AM
Shez's Avatar
I'm also running an HKS. No issues that I can see. My cars been running great for the past 5k miles.
Old Mar 23, 2010 | 09:53 AM
The car will go rich regardless when you let off the throttle. It then burns off quickly while decelerating and the motor is still pumping. All of the Subaru guys used to say the same exact thing. I then posted logs of either setup while logging and showed there was no significant difference.
Old Mar 23, 2010 | 10:29 AM
Hawaiian Whore's Avatar
i've had my hks ssq bov longer than i haven't had it, and never ONCE had a problem out of it... ever
Old Mar 23, 2010 | 11:08 AM
JPizzle's Avatar
X3 Guys ^^^ It's all about how you set it up.
Old Mar 23, 2010 | 12:25 PM
If its hooked up with the stock bpv it will work. if your just running atmospheric you need to recirculate or relocate the maf
Old Mar 23, 2010 | 01:20 PM
Shez's Avatar
Or tune for it.
Old Mar 23, 2010 | 01:24 PM
dont tell me going back to stock recirc is going to make you think you can beat slowshow....
and fix your sig
Old Mar 23, 2010 | 02:50 PM
ssturbo305's Avatar
Originally Posted by Shez
Or tune for it.
are you guys running it atmospheric?
Old Mar 23, 2010 | 03:02 PM
Shez's Avatar
Yep. Dejon charge piping with an HKS SSQV vented atmospherically and the stock bypass valve blocked off.
