N2mb wot box hookup
Old Jun 13, 2014 | 03:23 PM
eqaddictedfool's Avatar
N2mb wot box hookup
Hey guys. Going through my install for my new Wot box that showed up from modern performance. Im trucking through the instructions but cant seem to find the sensor it calls for on page 7. Anyone happen to have a pic or a better explanation of where I can find this on the LNF? Thanks
instructions-
http://www.npcompleteperformance.com...x/instructions
Old Jun 14, 2014 | 10:14 AM
cw383's Avatar
Cant help with the wiring, but in for the results, would love to see if that really helps shift smoothness at high rpm
Old Jun 14, 2014 | 02:09 PM
Old Jun 15, 2014 | 02:51 AM
kzak104's Avatar
probably because those are lsj instructions not lnf
Old Jun 17, 2014 | 12:02 PM
hucks1987's Avatar
That is the Ignition wire, Its on the #3 coil pack, needs to be cut in half, and one piece go to the red wire and then the black wire i think, Ill check when i get home.
Old Jun 20, 2014 | 11:50 AM
thanks ill take a look around for this when I get back to it. Im in the middle of a fuel issue right now so gotta sort that out first but this should help. Any more info ya can give me?
Old Jun 20, 2014 | 12:50 PM
dcrep06's Avatar
there is already a how to done by BYT for the lnf......
Old Jun 20, 2014 | 12:54 PM
dcrep06's Avatar
https://www.cobaltss.net/forums/2-0l...ll-lnf-215912/
your welcome lol
Old Jun 20, 2014 | 01:10 PM
WSFrazier's Avatar
Just an FYI, when I did the install none of the colors/wires that are in BYT's instructions matched up to my car. I was an early 2008, but I had to use a multimeter and find them myself.
Was actually wrong a couple times and ended up cutting/soldering wires back together for nothing.
Old Jun 20, 2014 | 01:18 PM
tuned08ss's Avatar
What is the point to have this on a lnf if we have launch control?
Old Jun 20, 2014 | 02:03 PM
so I can adjust it for a heavily modified car
Great find on the link. Ill give this a shot
Last edited by eqaddictedfool; Jun 20, 2014 at 02:03 PM. Reason: Automerged Doublepost
Old Jun 20, 2014 | 03:34 PM
dcrep06's Avatar
holy **** people. its not just for LC!!!! you can build boost off the line with it also for those big turbo guys -_____- its like a constant repeat, same stupid question.....
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
