Need help with ECU
Need help with ECU
I am about to buy a used ECU from a member on here(HB_SS/TC) and I would like to know what all do I need to get my VIN put on to that ECU so I can get a tune on it.
Would trifecta be able to do that if I mailed them my ECU, I also have a local tuner here and would he be able to load my VIN on to the spare ECU? Thanks, all info appreciated.
What was the answer?
I believe that Vince just tunes your car with the existing VIN. He doesn't actually change the VIN on the ECU to match the car. I don't know how he gets around it. If I did, I'd be a tuner.
I live between Topeka and Emporia.
I have HP Tuners, but I'm a noob. I think you have to "read entire" from the original ECU (just like you have to do if you want to license it and modify the tune). Normally, when you flash changes you just "write calibration only". But, if you want the new ECU to be exactly like the old ECU, open the old tune and use "write entire" instead on the new ECU (must be installed of course). After that, you can just do the "write calibration only" to make changes which is safer.
One tune, one ECU.
Another thing to keep in mind with HP Tuners is that it requires 2 credits for a Cobalt SS/TC. If you are tuning two ECUs, that requires 4 credits. Each credit is $50, so 2 ECUs will cost $200 just for the credits, not counting what the tuner charges for labor.
Twincharged
May 1, 2012 12:46 AM
