Need help with Evap Purge Valve Replacement
I replaced the Fuel Tank Vent Solenoid and took off the EVAP solenoid and shook it and my CEL is gone and has never come back. The mechanic also told me to replace my gas cap again as the seal on it is worn.
both parts above ive replaced recently just do them both. they are simple and need no programing
thats the code i had. when I got fuel it would take awhile for it to crank and go into engine power reduce with a cel then go back to full power
Had this happen to mine too a few years ago. If i didn't hit the gas after filling up when trying to start the car, it would die on me and not want to turn over again unless I let it sit a few minutes. When it started I would get engine power reduced. Replace evap purge solenoid under the hood and it cured all the problems.
If neither of those fix it, then you've got a leak somewhere that may require a dealer to do a test of the system to track down.
Depending on your miles, you can shell out about $50 and replace both the Evap on the manifold and the vent valve near the gas tank with simple hand tools.
Not sure if you have access to a lift or jack with jack stands.
With a lift, the vent valve by the tank is a 5 min job.
Ok thanks I'm going to order the purge solenoid? Just seen a video on YouTube on how to test the purge solenoid and mine is definitely bad. How do you remove the Vent Vale? Do you just twist it off? I have access to Jack stands and I know were its located.
For the purge valve on the intake manifold just unhook electrical and unbolt.
will this help me out at all?
i have a P0221 code, when im driving i get eng power reduced and my car has NO throttle response at all and have to turn my car off and turn it back to get moving again.
Do you lose power after you fill your tank up? That's what was happening to me and I replaced the solenoid and it fixed my problem.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
