NEED HELP GOT A CEL p0107
Old Sep 26, 2009 | 06:59 PM
MoePwR's Avatar
Exclamation NEED HELP GOT A CEL p0107
has anyone had this before? the dealer replaced the map sensor about a week or 2 ago for the same code. it went away and now its back again.... any help would be fantastic
Old Sep 26, 2009 | 08:06 PM
Iam Broke's Avatar
Loose connector? I was getting a P106 after I upped the boost beyond sensor range until I disabled the code. You might have blown it again.
Manifold Absolute Pressure Sensor
Electrical > 80 rpm 1.0 sec
P0107 circuit continuity - ground MAP sensor output voltage < 0.1855 V continuous 4 sec two driving cycles each with: 4 sec continuous or 50 sec cumulative
Old Sep 26, 2009 | 08:15 PM
MoePwR's Avatar
does it hurt to disable it?
Old Sep 26, 2009 | 09:25 PM
Iam Broke's Avatar
You need to find out if the sensor is still good. Clear the code and see if it returns right away. If it comes back chances are the sensor is bad again or you have a pinched/bare wire grounding out.
I knew why I was throwing a P0106 because of my over boosting.
Old Sep 26, 2009 | 09:31 PM
Projekt's Avatar
Your harness to your MAP sensor is fucked. Tell GM to replace that..its been a known problem
i popped my map sensor (p0107) they replaced it ..now i get p106 whenever i get on it
p106 is fine..p107 your done lol
Old Sep 26, 2009 | 09:42 PM
tomj77's Avatar
whats p106?
only problems im having is that dam anoying rattle under the dash on passenger side, sounds like its behind the apiller, but its not, im about ready to blow it up.
Old Sep 26, 2009 | 09:48 PM
Projekt's Avatar
rattles are due to the fact you purchased a GM
p0106 is a map sensor out of range...usally caused under heavy load. alot of agreesive-ly tuned guys have it .you can tune it off..but i keep it on just to know when i pop it
Old Sep 26, 2009 | 10:00 PM
tomj77's Avatar
well normal gm rattles i can handle but this one isnt normal. and i gotta take those stupid defroster covers off on the back window, those are the source of alot of rattleing
Old Sep 26, 2009 | 10:20 PM
MoePwR's Avatar
ok ill let him know mon. thanks man. i am boosting a lot though. it jumps to 30 for a sec
Old Sep 27, 2009 | 12:24 AM
Projekt's Avatar
Yeah. it means your map sensor is shot..get GM to replace it and go to stock tune
Old Sep 27, 2009 | 01:37 AM
MoePwR's Avatar
well why would it happen twice. i had the trifecta tune when it first happened which i was boosting 22
Old Sep 27, 2009 | 01:39 AM
Projekt's Avatar
its a bad harness from what i have read
Old Sep 27, 2009 | 01:40 AM
MoePwR's Avatar
ya i hope theyll believe me when i say what it is. i cant go back to stock tune but oh well ill take it in anyway
Old Sep 27, 2009 | 10:53 AM
RYRO14's Avatar
Yeah I threw this code at the track last night, cleared and it has not come back so I guess im fine.
Old Sep 27, 2009 | 12:54 PM
MoePwR's Avatar
ill go to vip and clear it and try that
Old Sep 28, 2009 | 11:19 AM
BYT*SS*TURBO's Avatar
Yea, this should not be from the tune. 0106 and 0234 are overboost codes which are disabled because you have my 25+psi tune on the car.
I just got home from vaca, will be returning your call a lil later
Old Sep 30, 2009 | 02:47 AM
MoePwR's Avatar
hmm still havent gotten off my ass to get the map sensor replaced haha. but maybe thurs i will
Old Oct 11, 2009 | 06:33 PM
Black08SSTC's Avatar
OK little thread revival here. I got the P0107 code, does that mean the wire harness is fucked or the map sensor. Its not a big deal if the sensor is popped, just if the wire harness is screwed ima **** sideways
Old Oct 11, 2009 | 09:17 PM
RYRO14's Avatar
Yeah my boost guage stopped working but I got no CELs? what does that mean?
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
