need pic of vacume lines
I need a pic of engine bay with the manifold vacume line setup. perferably someone with the vacume canister line relocated to the manifold due to having a lower charge pipe with no hookup for it. Pretty sure gm hooked mine all up wrong when i got a new motor and its causeing some weirdness.
This is how my lines are set up right now because when I bought my lower pipe used it had no vacuum fitting. It works fine like that but the bpv seems to open more than normal so I ordered a new fitting for the line. Gonna reroute them like stock once I have a free day.
And the lines on the pid controller need to be routed a certain way or it wont function correctly. If you dont have the boost reference hooked up from the lower cp i would just run the bov off the manifold. That way the whole vac tank and that tee system is completely removed.
k i got 2 lines coming from the vac tank, one goes to manifold at the moment, the other goes into the solanoid. if i wanna remove the tank, what do i plug into the solanoid in its place?
in fact someone just explain where all the lines go with the tank removed
I have the Treadstone Upper and Lower CP with the maf reloc and TurboSmart Bov this is how I set it up and works fine for me, hope it helps
Run the lines exactly like this and you will be fine. He id using the vacuum tank here whereas i was saying not to. Either way will work fine.
I totally bypassed the tank and solonoid today, doesn't work well with the upgraded bpv spring, not enough vacuum to open bpv properly. Guess that's what the tanks for. If I still had stock spring I'd see how that worked, I just put tank back in, believe my solinoid is bad though, it opens the bpv at 10+psi when I'm in higher gear at slower speed. When I bypassed it it didn't do it anymore, so I need new one
