need some help on clutch please answer
Old Feb 25, 2010 | 01:11 AM
pookie025's Avatar
Question need some help on clutch please answer
well soon ima get my clutch done and i bought the clutchmasters stage 4 6 puck. will i need a new throw out bearing. it didnt come with one, and will i need anything else to install the clutch. the only thing that came was the clutch only. sorry i really dont know to much about clutch installs.....
Old Feb 25, 2010 | 01:14 AM
sheldon729's Avatar
Should have bought your clutchmaster clutch from modern performance it comes with the gm slave cylinder
Old Feb 25, 2010 | 02:01 AM
pookie025's Avatar
thats where i bought it from
ok it did come with it... anything else i need... thanks
Old Feb 25, 2010 | 05:46 AM
sporttintturbo's Avatar
That's all I got with mine also, hahn had my flywheel reserfaced. Works good. Its as radical as I assumed and meaning that in a good way. Holding 370 I'm putting to the wheels.
Old Feb 25, 2010 | 06:01 AM
cmiller8006's Avatar
I would only change it if your over like 20-25,000 miles
Old Feb 25, 2010 | 06:04 AM
Mine started sliping at 10k will all hahns boltons and their ppc tune. She took a good regular beating thoe.
Old Feb 25, 2010 | 08:15 AM
glhs379's Avatar
had the same clutch put in a few weeks ago
only thing you will need is some tranny fluid
i reused my stock flywheel, did not even need any resurfacing at all.
Old Feb 25, 2010 | 10:06 AM
pookie025's Avatar
im at 26 k and will i need a new throw out bearing
Old Feb 25, 2010 | 10:10 AM
SSlobalt's Avatar
Damn, you guys are really racking up the miles.
Old Feb 25, 2010 | 10:12 AM
06BrandonSS's Avatar
When I bought my centerforce for my last SS it was recommended that I buy new flywheel to crankshaft bolts also, on CED's website.
Old Feb 25, 2010 | 10:47 AM
glhs379's Avatar
yes, you should not reuse the flywheel bolts if you unbolt it to change/resurface
Old Feb 25, 2010 | 11:59 AM
Yea I did forget about that, ******* bolts are like 90 bucks.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
