New Treadstone Products for LNF
Old Jan 26, 2011 | 01:17 PM
Treadstone's Avatar
Just wanted to let the community know we are working on our MAF relocation pipe for our intercooler kit. This will relocate the MAF in the pipe connecting to the throttle body, with this option the user will be able run an atmospheric blow off valve with no tuning issues at all.
Also, we are now putting honeycomb maf straighteners in our cold air intakes and MAF relocation pipe. This will straighten the air leading towards the maf sensor in the pipe, making this the best air intake available for the LNF. Fuel trim readings will stabilize and the car will have a much better MAF curve., Idle will be perfect, and HP curve will be cleaned up.
We already ranked pretty good when our cold air intake was tested, now well be #1!
This honeycomb will also be used in the MAF relocation pipe as well.
testings have shown very small pressure drops, almost immeasurable, which will not affect performance what so ever.
These honeycomb material and screen material are used in many OEM applications to clean up MAF readings, and we feel these additions will be an added benefit for any turbo application that we come out with in the future.
Old Jan 26, 2011 | 01:27 PM
cubaniche's Avatar
You guys are the first ones to finally put a real straightener in an intake. Props to you guys!
Old Jan 26, 2011 | 01:29 PM
Stamina's Avatar
Heck, maybe I should get one of these just to fix the issues with current intake solutions.
Old Jan 26, 2011 | 02:05 PM
TommyP's Avatar
AWD > FWD
Quick! Someone log their new intake with one of these!
Also, is this an insert (which could be used on other intakes) pictured or an actual integrated piece of the intake?
Old Jan 26, 2011 | 02:09 PM
cubaniche's Avatar
Looks like that honeycomb is tack welded in place. I would assume its only available as part of the intake or MAF relocate pipe. I have a piece of honeycomb thats deep just like that at home. Its pre-cut to 3in and ready to be put in my intake. Just been too lazy to take it in to a shop to have it tacked in place inside the intake.
Sorry for the threadjack. Looks like a quality piece OP! Great work adding that straightener in there
Old Jan 26, 2011 | 02:13 PM
Grishbok's Avatar
*APPROVED* Any idea when these will be available? or what kind of pricing were looking at?
O9cobaltSS's Avatar
props
Old Jan 26, 2011 | 02:19 PM
Treadstone's Avatar
We have the honeycombs in stock, only $20 each, 3" 3.5" and 4" sizes available, you just slide them in your pipe and wala! We have them pre cut to slide into aluminum pipe with .065" wall thickness. They just wedge in there. You can tack them, glue them, or braise them in if you want.
Ill put some pics up shortly
~jason
Old Jan 26, 2011 | 02:22 PM
Treadstone's Avatar
Guaranteed, this $20 option is a great fix for any intake or MAF pipe that has erratic readings!
Old Jan 26, 2011 | 02:53 PM
Stamina's Avatar
Wow, that's a nice option to have. I'll have to measure my K&N SRI diameter.
Old Jan 26, 2011 | 03:03 PM
cubaniche's Avatar
~jason
Thats awesome. I foresee you guys selling these like crazy
Old Jan 26, 2011 | 03:28 PM
snoftall's Avatar
Wow, this is awesome! Someone needs to get this and insert into the K&N intake and see how fuel trims work out! I would definitely get one of these if it helped the fuel trims settle down!
Old Jan 26, 2011 | 03:34 PM
misterspockyall's Avatar
YES!! So if we order a Treadstone CAI today it comes with the honeycomb filter?
Old Jan 27, 2011 | 05:06 PM
BooSSted's Avatar
Hey Jason,
Are you offering an option to upgrade to the MAF relocation IC pipes instead of the standard pipes that the kit used to came with. I am interested in doing this if we can work something out. I still haven't installed them yet because winter has been hell so far. I'd be willing to send back the 2 old pipes if you could still use them.
PM me if you'd like.
Matt
Old Jan 28, 2011 | 02:46 PM
Treadstone's Avatar
click below
HoneyComb MAF Mass Air Meter Airflow Straightener- TREADSTONE PERFORMANCE
HoneyComb MAF Mass Air Meter Airflow Straightener. These small additions to any cold air intake, turbo inlet pipe or anywhere a MAF sensor is located, will greatly improve the MAF readings "fuel trims" that the ECU sees. No more erratic MAF readings, fix lean or rich spikes, increase throttle response, fix idle, all of these can be improved with this $20 upgrade!
-Available in 3", 3.5" and 4" diameters.
-Slides right into pipe before MAF sensor
-Can be glued, braised, or epoxy'd in
Old Jan 28, 2011 | 02:51 PM
TommyP's Avatar
AWD > FWD
if this is tested and works well (i'm sure many will want to see this logged) this may profit you guys more than your intake
Old Jan 28, 2011 | 02:55 PM
Treadstone's Avatar
Whos up for some MAF graph comparisons, well give you one for free!
Old Jan 28, 2011 | 03:12 PM
paintballerr78's Avatar
can this be used on the stock airbox?
Old Jan 28, 2011 | 03:26 PM
Stamina's Avatar
This started as one kind of thread and everybody went crazy over the honeycomb and now it's about that. lol
Yes please!
Old Jan 28, 2011 | 03:29 PM
cubaniche's Avatar
Doooo it Stamina! We can both try it and compare CAI vs SRI with honeycomb installed lol
Old Jan 28, 2011 | 03:41 PM
Dart_SI's Avatar
Old Jan 28, 2011 | 03:49 PM
mrsilent13's Avatar
anything for the HHR? as far an intakes? im sure i could use this, if i wanted to use a BOV.
Old Jan 28, 2011 | 03:51 PM
cmiller8006's Avatar
I had one in my k and n.
Old Jan 28, 2011 | 04:14 PM
Black08SSTC's Avatar
What if i have aftermarket pipes? or if i have aftermarket hot side and factory cold side?
Old Jan 28, 2011 | 04:23 PM
cubaniche's Avatar
Nice! Did it stabalize the MAF readings any better? I know the SRI causes some turbulence so it should have helped some.
