NLS question
NLS question
When you no lift shift are you suppose to be in competetive mode or just traction off. The reason I ask is I did it once with each and in 2nd gear it seemed like it might have done a little better in competetive mode but could just be in my head. Thanks
There is traction control and electronic stability control. When you go into competitive mode and hold the button down for 10 sec it turns off the ESC. Which is really fun in the Sky btw.
competitive mode keeps ecs on, fyi... soooo best way to get the full "driver" experience as much as the pcm/bcm crap will allow is to hold the TC button for 10 seconds so it "disables" the TC and esc.
Iceberg
Sep 29, 2015 12:33 PM
