No boost in 1st gear!!!! LNF
Old Aug 10, 2014 | 04:02 PM
reybalt's Avatar
Hey guys, 2 days ago I noticed that the turbo gauge wouldn't go past 0 psi. I stepped on gas and the car felt slow. Then today I drove my Cobalt SS tc and the turbo seems to work but It can't reach any psi in 1st gear. Then 2nd,3rd, .. boost will be aaound 10psi. Any idea what it can be?
Old Aug 10, 2014 | 04:07 PM
AZ520SS/TC's Avatar
Boost leak, vacuum leak, dirty map sensor (putting your car into a limp mode) honestly sounds like a boost or vacuum though. When my car has a dirty map it sputters for a bit then goes into limp mode.
Old Aug 10, 2014 | 04:19 PM
reybalt's Avatar
In the right side near the motor I saw a hose that has another hose conneced in the middle and it is unattached and it is wrapped with some sort of sticky black cloth. COULD THIS BE THE PROBLEM?
Old Aug 10, 2014 | 05:26 PM
tomj77's Avatar
That plastic hose is the evap hose. Goes to ur canister back by the fuel tank and pushes fuel vapors into intake. Car won't run rite with that not connected but it wouldn't cause loss of boost. U have a leak somewhere. Check ur charge pipes and take off bumper and see if intercooler is cracked
Old Aug 10, 2014 | 05:56 PM
GreenySC2's Avatar
I thought these didn't push boost in 1st?
Do you have any codes being put out?
Old Aug 10, 2014 | 06:02 PM
tomj77's Avatar
course they do, that be kinda dumb if they didn't. 1st Is limited to about 10lbs of boost though
Old Aug 10, 2014 | 06:04 PM
reybalt's Avatar
Check engine light isn't on. By the way, im not sure if the car is supposed to build boost in reverse. do any of you know if it is supposed to because it doesn't. just saying
Old Aug 10, 2014 | 08:11 PM
kzak104's Avatar
It builds boost in any gear... Including reverse. Boost leak if it doesn't most likely.
Probaby builds boost in 2nd on because it's a longer gear/more load. Turbo can build a little boost but is over spinning trying to create it.
Old Aug 10, 2014 | 08:33 PM
SSlobalt's Avatar
If you put it in neutral, rev it, and show boost on the gauge, you have a bad TMAP sensor.
Old Aug 11, 2014 | 03:35 PM
reybalt's Avatar
hello recently the check engine light came on and it turns out to be these codes: P0101 (Mass Air Flow Sensor) & P0299. Any ideas anyone? 1st gear only gives 5psi and 5th is 10psi
Old Aug 11, 2014 | 03:37 PM
Boost leak, dont replace the MAF before you do a boost leak test or youre just wasting money
Old Aug 11, 2014 | 04:51 PM
Terminator2's Avatar
Yep not enough load to get much over 10 psi in first normally. Stock turbo with my wg rod shortened 6 turns from stock I used to hit 21-22 psi in 1st but normally it was spinning so badly and first was from 0- redline in the blink of an eye so I had to look at the data logs of my car to see it hit 245-250 kpa.
Old Aug 11, 2014 | 05:19 PM
kzak104's Avatar
20psi on first. I can only imagin. Haha
Old Aug 11, 2014 | 05:23 PM
tomj77's Avatar
I don't see how anyone would want more than 10, I know some other guys changed theirs as well in first, I believe its limited right?, and had same results.
Old Aug 12, 2014 | 09:19 AM
Yes the torque percentage is limited in 1st normally. I had mine cranked to 100% where I normally leave it around 55-65%. I did this so I could do long burnouts and if I got the throttle modulation just right it was pretty damn fast off the line that way.
Old Aug 12, 2014 | 09:27 AM
tomj77's Avatar
Lol never thought of that, throw in the burnout tune for competitions lol
Old Aug 18, 2014 | 02:04 PM
reybalt's Avatar
Update!!!!!!!!!
Hey guys, I just came back from the dealership and the problem was a crack in the intercooler. Lucky for me the warranty will cover the repair and thanks to all who tried to help.
Old Aug 18, 2014 | 02:12 PM
umrdyldo's Avatar
Dang you were lucky to get that warranty work.
Old Aug 18, 2014 | 09:58 PM
I'm surprised to hear that as well.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
