No codes running rich at idle only
Car is dumping fuel at idle afr is at 10:1 but only at idle. Even in the grass a little and every thing is right where it should be. Already replaced maf and both map sensors. High pressure pump is reading right what ecu is commanding. I’m going to replace the a/f sensor this week but if that doesn’t do it I’m not sure what to even check or replace after that. Any help would be awesome
Never mind you said the HPFP is reading fine so it's LNF. Any new mods? Intake, anything?
Is the cat light-off turned off? Use HPTuners to graph your front O2 sensor, does it oscillate properly when not idling? I'm guessing it does, since you're cruising AFR is spot-on.
EDIT: Actually, LNF's have widebands don't they... so I guess it won't oscillate.
EDIT2: might try reading through here: https://forum.hptuners.com/showthrea...-Warmup-Delete
Dominic Siriano
May 7, 2020 09:59 AM
