No-lift shift
Old Aug 31, 2008 | 02:15 AM
40rty's Avatar
No-lift shift
Hi everyone,
So got the new cobalt and decided to try out the nolift shift. I know I have to practice some more cause when I would no lift the rev would go pretty hi. Is this normal or do I have to shift even faster? What rev should I be seeing? Thanks.
40rty
Old Aug 31, 2008 | 02:42 AM
08blackbolt's Avatar
wuts up
me too same here i just picked up my blackbalt today n the no liftshift was weird. could someone brake it down a lil? by the way name is mario wuts up everyone
Old Aug 31, 2008 | 03:02 AM
40rty's Avatar
Welcome to the forums and congrats on the balt. Also, for Traction control, I thought that there was minimum tire spin when you had it on. I squel like crazy though. I'm guessing I still need some practice. Suggestions?
Old Aug 31, 2008 | 04:20 AM
Zander916's Avatar
It'll still spin some.
For the no lift shift. I don't know man... probably just need to shift faster. You only have .2 or .3 seconds to complete the shift and it helps if you can get as close to redline as you can.
As the engineers said... one exhaust pop is good. More means you've hit the fuel cutoff.
Old Aug 31, 2008 | 05:13 AM
40rty's Avatar
Nice, thanks for the advice.
Old Aug 31, 2008 | 02:02 PM
Tomtwtwtw's Avatar
Maybe a stupid question, but are you no-lifting at or near redline, or in the middle of the rpm range to just shift fast? If you try to no-life at 4k rpm then yeah, your revs are going to surge since the computer doesn't want you to shift like that during normal driving.
Also, you do need to be pretty quick about it. I believe 2 tenths is the window you get before it hits the throttle again.
Old Aug 31, 2008 | 02:14 PM
FiscalFizz's Avatar
I am assuming your 08/09 SS was new with no miles on it?
Just kinda shaking my head at the fact that your doing a NLS with a brand new car? If I am wrong and the engine/tranny was broken in nicely, then my bad. but yeah..
Old Aug 31, 2008 | 02:58 PM
slattone's Avatar
its reccommended that you do not do NLS until car is broken in but your car do what you want but if it is broken in you will need to have it close to redline as possible shift faster and you will hear the wonderful pop if done correctly.
Old Aug 31, 2008 | 11:58 PM
BIGTAG's Avatar
ive been using the no lift sncei pulled out of the lot i did frist to second and second to third as i was leaving the parking lot but you do hav to be as close to redline as possible cause there it any reason to use it any other time cause its supposed to keep yo spooling during shifts
Old Sep 1, 2008 | 01:55 AM
40rty's Avatar
I've only have done NLS once on my balt, stupid of me, yes with only 72 miles on it. I have all the time been very gentel with my new car. What is it 1500 miles and nothing pass 4500rpm's?
What are the consequences for not breaking it in, like you should?
Old Sep 1, 2008 | 02:27 AM
Zander916's Avatar
500 miles
not to exceed 5,000 rpm
not to exceed 100mph
no full throttle starts
do not run a constant speed for long periods of time
The purpose is just to seat the rings, valves and things of that nature. Otherwise it could burn oil it's whole life, things like that.
I've heard people who say (and have done with without trouble) to either drive it how you intend to drive it or drive it like you stole it.
I followed the manual myself.
Old Sep 1, 2008 | 02:45 AM
thanks now i kno its better to wait to stomp on it.lol.
Old Sep 3, 2008 | 10:34 PM
lwevert's Avatar
I read an article that say for the first 20 miles you should give the car as much hell as you can. Then do normal break in procedures. The first 20 miles are crucial to set the compression rings to the cylinder walls.
This is the article I found, the real one is on evoxforums.com
Old Sep 3, 2008 | 10:37 PM
chris88z24's Avatar
Make sure its in competition mode or else the no lift shift won't work.
Old Sep 3, 2008 | 11:00 PM
RooTBeeR's Avatar
...wow, bunch of newbs. The search tool is your friend, there have been many threads about the NLS already.
Old Sep 3, 2008 | 11:13 PM
jerrodmann's Avatar
yes there are threads multiple ones all over...
IBTL...
Old Sep 4, 2008 | 05:24 AM
steddy2112's Avatar
Not true at all. You have it no matter what. Comp, tcs off, esc off, regular...it's always there
Old Sep 4, 2008 | 08:41 AM
40rty's Avatar
I was going to ask, do all the SS's have the anti-slip diff or no? Also, is it wise to buy a turbo timer for the car? Thanks
40rty
Old Sep 4, 2008 | 10:24 AM
MapOfTaziFoSho's Avatar
Bullshit.
I had a GM powertrain engineer give me the exact same advice as the manual. Your engine builder knows more about your car than some article
For the first 500 miles I gave the engine light load and shifted easy, but still took it through varying levels of RPM up to 5k and then let it back down again. Accelerate slowly, maybe 25% throttle at most, and keep it in a lower gear, let the revs build up to 5k and then bring it back down, but don't pop the clutch...let the engine slow the car.
Old Sep 4, 2008 | 11:46 AM
Tomtwtwtw's Avatar
40rty
No and no. The LSD is a $495 option, and if the turbo is hot when the car is shut down, the fans will stay on and the coolant will circulate until it decides it's cool enough. On regular driving, I've had the fans stay on for maybe 10-20 seconds after turning it off. After a couple dyno pulls, the fans stayed on for almost 2 minutes. That's your built-in, fuel-saving turbo timer.
Old Sep 4, 2008 | 11:57 AM
SSpdDmon's Avatar
Page 2-21 in the owners manual = Break-in procedure
http://content.gmownercenter.yahoo.c...alt_owners.pdf
Originally Posted by MapOfTaziFoSho
Bullshit.
Also says to try to avoid engine braking.
Old Sep 4, 2008 | 12:03 PM
blackbird's Avatar
As mentioned, yes it will. I was curious about this myself and decided to do some testing recently to verify it. I've been putting some various videos together that I'll try to get posted in the next couple days.
For the no-lift shifting, remember all it does is help hold boost to get back into power better after the shift is completed. You want to start your shift right before red line and complete a normal, but quick, shift using the clutch pedal just like you would with any other shift. Don't try to force the shifter faster then it wants to go and don't hammer the gear change. Just perform the shift normally but slightly faster than normal with the only difference being that your foot keeps the gas to the floor.
Old Sep 4, 2008 | 12:56 PM
40rty's Avatar
Is the LSD something I can go back to the dealership and have them install or is that something that can't be done? Thanks
Old Sep 4, 2008 | 01:02 PM
I'm not talking about engine braking. Simply lifting throttle and coasting with it still in the selected gear.
Engine braking would be downshifting and quickly brining the RPM back up in order to slow down. Essentially, putting a lot of load very quickly on the engine.
Old Sep 4, 2008 | 01:05 PM
L.P.'s Avatar
Question about no lift where do you guys start to shift with the no lift function? Is 6k about right?
