No_ss build thread
Old Jan 12, 2017 | 08:00 PM
  #351
Originally Posted by no_ss
Also, the only difference between the 3/8 and 1/4 mounts is the 1/4 is same mount size as stock with a spacer, then the 3/8 is a bigger mount without a spacer.
So you have both and made the measurements you asked of others?
Old Jan 12, 2017 | 08:07 PM
  #352
KMO43's Avatar
I have had both, and will say I had more vibration with the ZZP mount by far. The ZZP mount was better than factory probably because it didn't allow much movement. The Powell mounts I have now though are better. With the same tire arraignment I could get wheel hop using the ZZP setup, have little to none with powells. ZZP mounts are pretty though.
I have never had any hop I have all 3 ZZP mounts without the spacer
Old Jan 12, 2017 | 09:01 PM
  #353
63 Nova SS's Avatar
Ever ran drag radials?
Old Jan 12, 2017 | 09:14 PM
  #354
post because for some reason 63 Nova's posts wont show up until I do.
Edit: **** it didn't work
Edit2: it does not
IB can we fix this issue it's starting to get extremely annoying
Old Jan 12, 2017 | 09:24 PM
  #355
no_ss's Avatar
I dont really notice any vibrations at all. I dont have wheel hop at all. Maybe you guys are speaking of the first zzp spacer. There is a gen2 and a gen3 now. Gen3 is a bigger mount and is 3/8, gen2 is 1/4.
Old Jan 12, 2017 | 10:39 PM
  #356
KMO43's Avatar
No just Nt01s maybe this year
Edit2: it does not
Yes everytime Nova posts it shows up he was the last to post but his posts dont show
Old Jan 13, 2017 | 01:20 AM
  #357
no_ss's Avatar
I have gen2 zzp rear mount. I've spoke to someone that has powells. From what I can tell theyre almost the same thing.
Old Jan 13, 2017 | 05:37 AM
  #358
63 Nova SS's Avatar
Does this one show up? I am still randomly using the old app.
Btw the ZZP mounts I ran didn't have spacers that I remember, like powells do and I had pretty bad wheel hop. I'm glad they have changed that. And the vibration was noticeably more than stock or powells. And when I installed them I did loosen things to try make sure things were able to settle and rotate.
Old Jan 13, 2017 | 06:14 AM
  #359
KMO43's Avatar
Yes this one did. The gen3 has the spacer built in you can buy the spacer for the older ZZP versions. I am not one to ever complain about vibrations and I am told my car is now a racecar so that doesn't matter.
Old Jan 13, 2017 | 07:24 AM
  #360
no_ss's Avatar
The new zzp mounts are also solid rubber, not polyurethan bushings. So you couldve had the polyurethan which is stiffer and causes vibrations.
Old Jan 13, 2017 | 07:29 AM
  #361
KMO43's Avatar
Mine are old and are rubber. I've had them on for at least 50miles with no cracks or tears
Old Jan 13, 2017 | 08:54 AM
  #362
I dont think they've ever made poly bushings for the cobalt
Old Jan 13, 2017 | 06:42 PM
  #363
no_ss's Avatar
they made mention of using poly bushings a long while ago.
Old Jan 17, 2017 | 07:44 AM
  #364
no_ss's Avatar
So bump for proof of the powell mounts being better and how the angle of the transmission has to do with suspension geometry.
Old Jan 17, 2017 | 08:18 AM
  #365
I really doubt anyone other than Powell will have that info. Everyone goes by feel
Old Jan 17, 2017 | 09:10 AM
  #366
no need to explain to you since you already believe they're the same and I can save money by buying zzps.
Old Jan 17, 2017 | 09:24 AM
  #367
Burn ^
Old Jan 17, 2017 | 01:36 PM
  #368
no_ss's Avatar
Okay, zzp mount same size as stock. Same amount of spacing under the zzp mount as powell. Explain to me how the axles have to do with suspsension geometry, now that I've asked this for second time because it does not. Hes not burning anyone. He hasnt proved any of the info hes claiming and hes getting defensive with sarcastic comments. Ecaulk is wrong. Done.
Old Jan 17, 2017 | 01:41 PM
  #369
You said you didn't compare them side to side.
Suspension geometry does come into play with axles on fwd, you know since the axle is connected to the knuckle and travels up and down with the axle inside of it...ever watch a car launch?
Old Jan 17, 2017 | 01:44 PM
  #370
no_ss's Avatar
You should really learn more. Im in school and I've learned all about suspension geometry. Youre wrong. Do some research.
Old Jan 17, 2017 | 01:49 PM
  #371
Seriously?
Congrats on being in school
You tell me to do research, yet you provide no proof of your statements you've claimed to learn...
Old Jan 17, 2017 | 01:51 PM
  #372
no_ss's Avatar
Seriously?
tell me where camber, caster, toe, steering axis inclination, scrub radius all have to do with axles.
Old Jan 17, 2017 | 01:52 PM
  #373
no_ss's Avatar
Maybe if it were a live axle rear end without independent suspension would you slightly have a chance at being right as that suspension effects the other side but its not.
Old Jan 17, 2017 | 01:59 PM
  #374
07blackg5's Avatar
Slobodan Milošević
Old Jan 17, 2017 | 02:00 PM
  #375
You're not understanding what I'm talking about and I have a feeling I'll never be able to explain it to your level of acceptance so I'm leaving it at this:
Go back to school and learn about physics, specifically rotating objects in multiple planes.
Also I'm not going to waste time comparing a set of zzps to Powells, Powell generated them first while working with GM. Anything after that is at best a damn copy, yea they might look different but the important points are copied.
