Oil Blow by / smoking issue
Old Nov 3, 2013 | 12:37 PM
CalebPatton's Avatar
Hey guys. This is my first post here.
I've done several searches & have gotten mixed answers. Figured I'd make my own thread & see what you guys say.
Okay, so old turbo on my 08 SS blew, the car smoked due to the oil from the blown turbo of course. Never smoked before that.
My car has 60k on it.
Okay, so I bought a new stock turbo. No shaft play, was fine on the car before. This turbo is perfect. Got everything installed last night. Now I figured the car would smoke a bit at first burning some of the old excess oil off. But I've driven probably 70 miles now & still have the same problem. It only smokes at idle though. I checked the intercooler for oil, there was none. Some old residue on the intercooler piping but all was good.
I'm not losing any oil it seems either. I've checked it often.
What could be causing this?
The plugs are shot I'm sure, which are being replaced today, but that shouldn't cause smoke.
It's definetley burnt oil smell, not coolant.
Maybe an oil feed line problem or something? Need some help guys.
Mods are just intercooler, Intake, & pretty much straight piped.(done by previous owner. Fixing this after I figure this problem out.)
Thanks!
Old Nov 3, 2013 | 03:31 PM
blueLNFftw's Avatar
Why did the old turbo blow?
Do you have a cat?
If you have a cat it is filled with oil and needs replaced most likely. Could take a while to burn out.
Old Nov 3, 2013 | 03:43 PM
I pm'd you.
Old Nov 3, 2013 | 03:46 PM
George Osito 10's Avatar
It will awhile to burn out if did oil the cat try running at least 150 to 200 miles
Old Nov 3, 2013 | 03:50 PM
No cat guys.
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
