oil/coolant line specs
need to know the diameter and thread pitch of the banjo bolts on the oil feed and two coolant lines for the stock LNF turbo
thanks
Jim
bump, 60k member forum and no one knows the answer?!
thanks
Jim
Had I seen this on Friday evening I could've told you. Was helping a friend rebuild his engine with forged hardware this weekend. Well... more like "advising"... he already had all the help he needed by the time I got there.
How about just looking up the part? Usually the specs are a part of the description.
the only thing i don't have so far is the thread pitch for the banjo bolts, i know all the banjo fittings are 10mm inside diameter, but the oil and coolant banjo bolts are different. i just ordered the oil banjo bolt from the saab dealership since i have the saab oil feed line. as far as the coolant lines go, i allready have the banjo bolts so i just needed to order 10mm inside diameter banjo fittings with barbed ends.
and we don't have a fastenal here in germany lol
yah but getting parts over here is a real bitch, most of the stuff i ordered from the states. gotta figure almost all of the european ecotecs are rear breathers, very few standard eco's.
