Oil in Exhaust: Smoking..
Old 06-03-2016, 09:20 AM
:ninja:'s Avatar
Recently car has been having oil within the exhaust, smokes after driving for 5mins..
I have changed the pcv still same thing happens, next step is to clean charge piping & fmic.. Friend did a compression test for me while I was out of town said it checked back on 180 all around?? Idk I'll end up doing my own shortly.
Car drives fine and boost fine, no weird noises if I drive a tad bit harder than normal crusing it smokes earlier and more..
What could it be? I've been told cylinder head, turbo seals & injectors..
Old 06-03-2016, 10:30 AM
umrdyldo's Avatar
Yes check all of your piping and FMIC for oil. Take your intake off and check the turbo for shaft play.
If you don't find an external oil leak anywhere, lines etc, then you most likely have a turbo seal problem.
Old 06-03-2016, 10:36 PM
:ninja:'s Avatar
Will do that, any other suggestions anyone can recommend???
Old 06-03-2016, 10:43 PM
tomj77's Avatar
Welcome to my world . I have yet to take my motor apart and find out why mine smokes. Could be ur turbo if it's doing it constantly after 5 minutes
Old 06-06-2016, 08:00 AM
:ninja:'s Avatar
Have you taken it apart yet?
Old 06-06-2016, 03:42 PM
tomj77's Avatar
Nope, I'm reorganizing my shop right now. Maybe I will this weekend
Old 06-09-2016, 02:09 PM
:ninja:'s Avatar
Found an oil leak for valve cover gasket
Old 06-11-2016, 07:04 AM
:ninja:'s Avatar
Swapped out gaskets still smoking, going to use brake cleaner and pull off charge piping to clean any oil within it...
Checked plugs no oil on them.. 🤔
Not sure what else to do.. Maybe oil connector out wrong place after motor was put back together..
yellow_cobalt
04-03-2016 09:20 AM
no_ss
03-30-2016 10:20 AM
Djboilore
03-29-2016 07:35 PM
DarrenGC
03-21-2016 11:25 PM
user 72239
03-09-2016 10:59 AM
Quick Reply: Oil in Exhaust: Smoking..
