oil filter cap size
Old Feb 3, 2010 | 06:13 PM
edge50's Avatar
oil filter cap size
can someone tell me the correct size socket fits my oil filter cap on my 2007 ss supercharged?? 2.0 ltr. eng. thanks
Old Feb 3, 2010 | 06:24 PM
09CobaltSS1's Avatar
wrong section my friend, but if it's the same as the LNF it should be 1 1/4" socket I believe
Old Feb 3, 2010 | 07:15 PM
slowbalt84's Avatar
which in metric is either a 32 or 33mm. I can't remember which one
Old Feb 3, 2010 | 07:34 PM
tomj77's Avatar
its 32mm
Old Feb 3, 2010 | 07:53 PM
Nighthawk243's Avatar
32mm, but 1 1/4" works the same.
Old Feb 3, 2010 | 07:58 PM
edge50's Avatar
cap size
thanks for the help, i'll get a 32mm. socket
Old Feb 3, 2010 | 08:19 PM
slowbalt84's Avatar
Originally Posted by tomj77
its 32mm
thanks tom. I always forget if it's 32 or 33. lol
Old Feb 3, 2010 | 08:21 PM
tomj77's Avatar
will a socket even work seeing as its square. i should try, would work better then a wrench
Old Feb 3, 2010 | 08:56 PM
tmharsh's Avatar
If you're going to an auto parts store to get a socket, you might as well get the one specifically made for the cap. It's short so it fits in easily. I believe I found it over by the oil accessories (filter wrenches, etc.).
Old Feb 3, 2010 | 10:08 PM
Hill1513's Avatar
Advance sells one for $12. It's a short 32 mm socket for ecotecs.
Old Feb 3, 2010 | 10:54 PM
krispy's Avatar
^this^
get it, normal sockets will probably be too tall
Old Feb 3, 2010 | 11:05 PM
tmharsh's Avatar
I forget whether I was able to get a normal 1/2 drive socket in there or had to resort to some other method. But I know using a standard socket didn't go so well. With the special socket you can just place it on the cap and then feed an extension down to it. Very little clearance over the cap on an LNF, I would imagine other versions of the ecotec are the same.
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
