oil gallery port
Old Feb 27, 2009 | 05:25 PM
tomj77's Avatar
oil gallery port
i noticed that there is another oil gallery port on the head by the obvious one in the middle of the head, but more towards the back, has anyone tried an oil pressure sender on that one and if so does it read proper psi unlike the one in the middle of the head.
Old Feb 27, 2009 | 06:07 PM
08BlackSS/TC's Avatar
Use the one closest to the pulley. I used that one for my sender. I will take pics tmw if you want?
Old Feb 27, 2009 | 06:21 PM
tomj77's Avatar
yes please do cause i went under the car and looked and if its the one i saw i dont thing it would work, it was on the back and the drive shaft is in the way so it might not be the one u mean. so please, pics.
Old Feb 27, 2009 | 07:20 PM
Jn2's Avatar
Jn2
oil in the head is restricted, ull get a reading, but it wont be accurate
Old Feb 27, 2009 | 10:46 PM
I'm referring to one of the three oil gallery plugs (1 towards the left of the exhaust manifold is being used for the turbo right now, 2 is right under the exhaust manifold, and 3 is the one closest to the pulley on the right of the exhaust manifold <--- the one I used)
Old Feb 27, 2009 | 11:01 PM
Jn2's Avatar
Jn2
oh ok yeah those are fine than i thought u ment the ones on the side of the head
Old Feb 27, 2009 | 11:43 PM
Old Feb 28, 2009 | 12:35 AM
tomj77's Avatar
show me pics
Old Feb 28, 2009 | 12:49 AM
Jn2's Avatar
Jn2
see the blue circle, the ones in the same horizontal line as it
*ignore the red circle*
Old Feb 28, 2009 | 01:44 AM
tomj77's Avatar
so ur using the one that is circled in blue?
Old Feb 28, 2009 | 03:59 PM
I'm using the same one. Here are some pics for you to get the idea.
Old Feb 28, 2009 | 04:15 PM
Jn2's Avatar
Jn2
yes he is using the one circled in blue as you can see in the pics above this post, the plug is a 6mm allen
Old Mar 1, 2009 | 01:11 AM
tomj77's Avatar
do u need to wrap the sender wire in heat wrap or something or is it safe from melting?
Old Mar 1, 2009 | 01:14 AM
Jn2's Avatar
Jn2
use wire loom
leave some slack in the wire to keep it away from any hot objects, do not let it touch anything in the exhaust directly(inc. turbo)
Old Mar 1, 2009 | 09:51 PM
tomj77's Avatar
ok i took a look and tried to get the plug off, how the heck did u do it? there is almost no room to work, i couldnt even get my allen wrench go in. i tried to modify it but that didnt work. so how did u do it?
Old Mar 1, 2009 | 09:53 PM
Jn2's Avatar
Jn2
i used a allen, than grabbed the allen with some pliers, and twisted it, if you can twist ti break free, it will thread out by hand, also i had the exhaust off :p
Old Mar 2, 2009 | 07:01 PM
tomj77's Avatar
ok having the exhaust off could help, why didnt u say so. lol i dont think there is any way to do it without taking it off. dangit. should have just got dealership to do it today since they are fixing my sunroof anyway, and checking all the bolts from when they installed the new motor, since i found one that wasnt tightened. and my axle is leaking greese. :P ****, im gonna take it there tomorrow and see if they can just do it.
Old Mar 2, 2009 | 07:17 PM
Sentry's Avatar
I had the same issue. That thing is a royal pita.
Use a 6 or 7mm allen socket with an extension, if you strip it use a T-40 star socket.
Old Mar 2, 2009 | 10:09 PM
I just had the dealer take that bolt off for me. It really is a PITA and they even had trouble getting it off!
Old Mar 3, 2009 | 09:22 PM
tomj77's Avatar
well i tried to get it off today so id know how to do it when i got my adapter fitting, and after figuring out the right combo of tools to use, it took me about 10 minutes to get it off, surprisingly it took less time getting it back on. lol so now i know how to do it, shouldnt be to hard when i get my fitting. woohoo
Old Mar 3, 2009 | 09:24 PM
tomj77's Avatar
Old Mar 3, 2009 | 09:38 PM
Jn2's Avatar
Jn2
cool cool have fun :p and yeah u needed the autometer adapter
http://www.turbotechracing.com/produ...dcategory=5623
Old Mar 3, 2009 | 10:18 PM
tomj77's Avatar
u ever heard of rev for the ipod?
Old Mar 10, 2009 | 11:18 PM
tomj77's Avatar
well i got my fitting today and installed my oil pressure sender, gave me some trouble, but not as hard as i thought it would be. now lets hope the wires dont melt. lol got my temp sensor adapter for the upper rad hose to, all works great, hope the hose doesnt blow apart, it tightened it pretty good, but not to much so i think it should hold. Also got my sunroof fixed so it goes down flush with the roof, they had to order a part for it, it looks great now. no just to get my windows tinted on thursday and wait for my cai, and my elm2 wirless obd2/can thingy so i can use rev on my ipod to get all the info that the performance display gives the 09's and ill be set. sweet.
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
