Oil in the intercooler???
I took the boost tube off the car today to install the Stage kit sensor and noticed a little oil was dripping out of the tube and from the intercooler... the stock sensor also soaked in oil.
The car ran fine earlier this morning (did a quick 3rd to 4th pull under full boost) before I parked her to cool down for the Stage Kit install , no codes nothing.
Anybody had this? That can't be right.
Update
Ok, it was not as bad as I thought... maybe a teaspoon of oil total.
I took the intercooler plus all the tubes off the car and cleaned them properly with a degreaser. Everything went back smoothly, new sensors installed and ready for my 2 pm reflash tomorrow.
BTW I noticed that I do not even have a snorkel from the airbox into the fenderwell
On the shorter tracks like DDT and Shannonville Fabi I might not gain anything for the car is already traction limited in 2nd unless I get a set of R6's or something...but on Mosport she is really going to fly once I figure out the new shift points! All that midrange TQ is what you want on the big tracks.
Ebay has plenty of them ranging from $20 and up, any sealed catch can will work, you don't want the vented style.
The steel braided line on the side of the valve cover is the one that you want to run to the catch can, its a pita to take off from the turbo and even more pita to disconnect the swivel fitting from it. In the end it should look like this.
I didn't see any
http://www.modernperformance.com/tur...3_624_674.html
I don't really trust e-bay parts especially not on a new car that's just my opinion though.
PS: What car is that a picture of?
Or goto ikea and pick up a stainless steel can and add some fittings to it.
The car is a solstice gxp, same lnf engine and rwd.
Actually a quality catch can would be best on these cars. It needs to be sealed and well baffled by some form of media. Mostly because synthetic oil is much more difficult to condense. Most of the ebay ones you'll find are not sealed well OR have zero baffling. Improvising an air compressor water separator would be better IMO if you must do it on the cheap.
I'm working on a nice lil plug n play system for my car using the proper russel 3/8" fuel fitting adapters + -6 lines. Not for everyone, but I'm one of those "do it right the first time" kinda guys.
Not trying to preach to anyone, but do some research on the matter and you'll see what I mean.
Being this is a direct injected car, I think putting a catch can on is important.
importkiller
Sep 30, 2015 07:18 PM
