Oil Line Help
Old Aug 1, 2010 | 04:00 PM
2006RedCobaltSS's Avatar
Oil Line Help
I need to order the oil lines for my s256. Can someone please post links of what I will need to order. I'm a noob when it comes to this. I know it -10 AN I think but having hard time making sure about it. I have 3 things to go before everything is done. Oil lines, downpipe, intake
Old Aug 1, 2010 | 04:46 PM
tomj77's Avatar
why dont u ask zzp if they can sell u some
Old Aug 1, 2010 | 04:49 PM
slowbalt84's Avatar
you definitely want to make sure because on some turbos you can reuse the feed line but the usually the drain line needs an adapter to fit but can also still use the factory drain line
also i am guessing thats you mike. This is rob btw. If you want to see if the fitting are the same size as my Precision 5457 we can compare and see. I know for a fact that I can reuse my factory lines on mine
Old Aug 1, 2010 | 05:13 PM
Yes this is mike. And id be happy to. I sent Matt m a message. I need to get almost everything ordered then see where I'm at when it's install time
Old Aug 1, 2010 | 05:48 PM
slowbalt84's Avatar
I have an adapter on the way as we speak for the oil drain line. Honestly i woulda made my own but didn't know the sizes or anything. If it fits your turbo too then we can jimmy one up.
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
SlowSaturn
Sep 28, 2015 11:03 AM
