oil pressure
Old Dec 11, 2011 | 12:04 AM
tomj77's Avatar
oil pressure
what kinda oil pressure u seeing at idle ??
Old Dec 11, 2011 | 03:04 AM
cmiller8006's Avatar
23-26 depending On how hot the motor is. 50 cruising at 55 60 at 65 and 80 plus at wot.
Old Dec 11, 2011 | 11:12 AM
tomj77's Avatar
well im seeing about 30 at idle. 25ish when my oil is at 45% life. just making sure i got enough. 30 seemed low. but it all checks out now
Old Dec 11, 2011 | 05:27 PM
After running around and getting things hot you still see 30? Thats real good
Old Dec 11, 2011 | 07:32 PM
tomj77's Avatar
ya, 29-30. been like that since iv been paying attention. as the oil gets older it drops.
Old Dec 15, 2011 | 04:36 AM
hallss's Avatar
How are you reading oil pressure?
Old Dec 15, 2011 | 08:39 AM
Oil pressure gauge. Put an autometer in my car.
Old Dec 15, 2011 | 08:47 AM
cubaniche's Avatar
Didnt know we had the ability to read oil pressure. Does it just read it off the OBDII?
Old Dec 15, 2011 | 08:56 AM
Axelthered05's Avatar
I get 30-45 at Idle 60-80 crusing and 100-120 at wot, im measuring that with a glowshift red digital oil pressure gauge and I use castrol edge synthetic oil
Old Dec 15, 2011 | 08:59 AM
you might be able to but corect me if im wrong I think the sensor in our cars is an oil switch which just turns on when oil pressure is not right I just installed an oil pressure gauge and sensor using one of the ports on the head directly under the exhause manifold, there are a few "how to" threads on here about it
https://www.cobaltss.net/forums/how-...-gauge-152253/
https://www.cobaltss.net/forums/how-...-0l-lsj-54553/
Old Dec 15, 2011 | 09:41 AM
No you can't read oil pressure through obd2. You actually have to put in a sending unit and all. It's actually easy though.
Old Dec 15, 2011 | 10:48 AM
cubaniche's Avatar
Got it. Cool ok. Thanks for the links.
Old Dec 15, 2011 | 10:53 AM
Boosted4's Avatar
I've been thinking about adding an oil pressure gauge myself. Glad someone brought this stuff up, I must've missed the original How To threads lol
Old Dec 15, 2011 | 12:17 PM
iboost's Avatar
sub'd
Old Dec 15, 2011 | 05:18 PM
Ok here's a question. Where is everyone tapping into. Mine is the hole on the from of the
motor all the way to the driver side.
Old Dec 15, 2011 | 08:12 PM
slvrred-'s Avatar
^^^^ Picture would probably do more justice....just saying, lol
Old Dec 16, 2011 | 09:12 PM
tomj77's Avatar
yes, im talking to the people with oil pressure gauges installed, cant read it any other way. tap into gally plug under the turbo, u need an adapter fitting
im guessing those higher numbers are when the oil isnt heated up
Old Dec 16, 2011 | 09:20 PM
I am tapped into a plug on the front side of the motor.
Old Dec 16, 2011 | 09:29 PM
See the three plugs on the front side, I used the one all the way to the right, it is where the oil pressure will be the least, so I know if I have good pressure there then the rest of the motor is great.
Old Dec 16, 2011 | 09:38 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yeah that's one of the galley plugs. i did mine the lazy way. lol took out the factory sensor, screwed in the autometer metric adapter and put in the sending unit. has worked perfect for the last 10,000 miles
Old Dec 16, 2011 | 09:57 PM
I was going to do that but didnt know if it would put on a light or anything.
Old Dec 16, 2011 | 10:03 PM
BLAZIN07SS's Avatar
I'm too JDM for you
it didn't turn on any lights for me. i turned off all the oil pressure stuff in hpt anyway.
Old Dec 16, 2011 | 10:18 PM
LS6Rally's Avatar
Mine is on the side of the block by Cyl. 4. Seems to work ok. i have a 2.4 i have 20 at itle once warm adn about 40 at 65-70. (2K-2500 RPM)
Old Dec 16, 2011 | 10:21 PM
BLAZIN07SS's Avatar
I'm too JDM for you
mine at idle is ~25. cruising is ~55-60. wot is ~90
Old Dec 17, 2011 | 09:39 PM
tomj77's Avatar
idk if the 2.4 is the same as the 2.0 but the one in the side, (thats if its on the head, reads low numbers, cause ur numbers seem a little low.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
