Oiled vs Not (K&N v. AEM)
Im getting ready to order my Dejon SRI, and Im wondering what do you guys think is better.... the K&N oiled filter or the AEM dryflow filter? I have always used K&N, but I had heard some people on here saying they thought it would be better to go with a dry filter to avoid getting oil in the turbo...? what do you guys think?
Looking into the AEM a little more, the dry flow sounds pretty good. It seems like its a lot easier to maintain. Do you guys think it filters as well as the oiled filters though?
Thanks for the advice
I do plan on a tune at some point. Im just waiting to see what GM offers...if its nothing good Im going to go with Trifecta. So either way I will tune at some point. Im just wondering if I shouldnt be doing the intake until after I tune.
The car will run more efficiently. Hece it will boost less to make the same amout or slightly more power than stock. What the ECM does is it measures the incoming airmass and if it exceeding the desired airloads the ECM has programmed into it. It will lower the boost pressure to keep the stock DALs. Get an intake and your other mods then get it custom dynotuned.
Oil filter...... What does a oiled air intake filter have to do with an oil filter???????
But, I have a K&N Drop-In Air Filter & I LOVE it. It's a quality product. I really don't have any answer on which filter you should buy.
my k&n has been on the car for almost 40K miles and i have had no problems, the only cel i have is due to lack of cat lol.
good info>>> http://www.knfilters.com/MAF/massair.htm.
Last edited by phatnackySS; Mar 23, 2009 at 12:11 PM. Reason: Automerged Doublepost
oil dosnt come off the filter if its oiled right. and even if it dose come off it wont hurt the maf.
Last edited by 80vetteL82; Mar 23, 2009 at 12:27 PM. Reason: Automerged Doublepost
he was simply giving you information on the AEM dryflow filter .... No need to cry about whether it's an LNF section or LSJ section. The AEM dryflow filter for the cobalt first came out on the SS/SC C.A.I., so you should listen up to the LSJ guys, because we have experience with the AEM dryflow filters. The AEM dryflow is a great filter, much easier to clean. Also, like many have said the K&N will not ruin a mass air flow sensor, unless it is oiled wrong. Both filters are great, and should give the same amount of performance. It's all up to what you like.
just letting him know. he was new
well i dont have an lnf but i have an lk9...and with the k&n it piut my saab into limp mode as soon as i fired it.....so i tend to stay away from them now.....now i have a DIY 3" intake and no cell at all....does the same job as K&N...with out a cel or limp mode....btw i only spent $30 on it..
thanks for the input guys! Im going with the AEM for the simple fact that it will be easier to clean. Thanks again for the advice. Ill make a post of the install once the parts get here.
it only caps the peak hp, doesnt let u got over 260/260, doesnt mean it wont let u pick up more hp threw the rest of the rpm range. for inctance if u have 200whp at 4000rpm, with the intake u will get 210 at 4000 rpm. u still gain, u just wont go over 260/260 when u hit ur peak hp.
