Oils
Old Apr 22, 2011 | 06:09 PM
BlackLsCoupe's Avatar
Oils
i know this has been asked before but search doesnt work for me, is it ok to run 0w30? i changed the oil today useing that mobil 1 0w 30 with an oil additive
Old Apr 22, 2011 | 07:54 PM
no answers? i read on there site its fine one guy had an SRT4 and is useing 0w40 is that better
Old Apr 22, 2011 | 07:57 PM
Turbalt2010's Avatar
id run 5-30 considering thats what gm says?
Iam Broke's Avatar
I discussed this with John Powell on another forum. Our LNF's were designed for 5w-30 Mobil 1. I use the Extended Performance stuff. Bill Duncan, the GM Engineer had posted in the past that the cam actuators get funky on 0w-30 after the oil breaks down a bit. I doubt 0w-40 would be any better.
Stick with 5w-30 Mobil 1.
Old Apr 22, 2011 | 08:02 PM
ok im only testing this for MPG, itll only be in for 5k miles thats why i added the oil additive from BG its good ****. in the owners manual it said 5w30 and 0w30 for the 2.2 and 2.4
Old Apr 22, 2011 | 08:14 PM
kplaya186's Avatar
I use 5W-30 Pennzoil Ultra, and I have noticed significantly less vavletrain noise
Old Apr 22, 2011 | 08:49 PM
xodus's Avatar
i used valvoline full syn, and it broke down alot slower than the Pennzoil full syn
Old Apr 24, 2011 | 01:04 AM
CurrentlyPissed's Avatar
Doubt it.
If by breakdown you mean was dirtier sooner. That was actually the better oil (pennzoil) cleaning the motor that much better. Dirty oil = good oil.
Read up on oil.
I use Pennzoil Ultra. There is no better oil on the market right now and helps cut down on our blow by significantly. Since the oil is designed for high performance cars only. Plus independent test shows that it has nothing even within sight as far as sheering, pressure, etc. It's a great oil and I'd suggest reading up at bobistheoilguy.com
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
