P0011 Camshaft problem!
Old Sep 1, 2012 | 02:50 PM
FrossB's Avatar
Thread Killer
Originally Posted by Iam Broke
My intake cam actuator died at around 50k miles on the LNF. Common issue. Would work ok until I drove it ~30 miles. Once it got pretty warm it would get flaky while logging then the ECU would disable it.
Your actuator took a **** or the actuator solenoid?
Old Sep 1, 2012 | 02:54 PM
exninja's Avatar
^Actuator, or actuator solenoid valve?
I was able to measure the resistance on the intake solenoid and it's 24ohms. I'll go get a new one today.
09Sp0rt's Avatar
I just has mine replaced this morning at the dealer. Not in warranty unless you have your 3 year 36000 mile bumper to bumper. I didn't have that, costed $247 and some change. They said if I didn't get it fixed it would cause starting issues and lead it to not start later down the road.
Old Sep 1, 2012 | 02:58 PM
09Sp0rt's Avatar
For the record my code was P0013, essentially the same thing. Different section I think.
Old Sep 1, 2012 | 02:59 PM
FrossB's Avatar
Thread Killer
i believe the P0013 is the exhaust side? but yes...same thing. Was yours the solenoid valve or the actuator?
Old Sep 1, 2012 | 03:05 PM
09Sp0rt's Avatar
Actuator I believe. Car runs like new now. I got tired of jackin with it and finally took it in
Old Sep 1, 2012 | 03:07 PM
FrossB's Avatar
Thread Killer
right on. well im just waiting to get paid next week so i can buy that actuator and get mine running right lol
Old Sep 1, 2012 | 04:47 PM
09Sp0rt's Avatar
Yeah mine started running like a wet cat so I went ahead and ate the $247 -_- hope yours turns out well!
Old Sep 1, 2012 | 04:49 PM
FrossB's Avatar
Thread Killer
mine seems to run fine when driving normal. but under load or in any boost it doesn't run right. I dont spool till way late...like 6000rpms to reach 20 psi
Old Sep 1, 2012 | 06:46 PM
Iam Broke's Avatar
The actuator solenoid that sits on top of the engine near the passenger side. P0011 code. The feedback position sensor on the end of the camshaft (drivers side) was fine.
Old Sep 1, 2012 | 06:57 PM
  #36
exninja's Avatar
I am reading on another site that someone with a Malibu had this issue and the vavle was covered under the powertrain warranty, anyone else have experience with this? This was the post from a "Customer Service" person:
@Sorb555, here is some information as to what the Powertrain Warranty should cover for your 2008 Chevrolet Malibu.
Gasoline engines - Cylinder Block and heads, and all internal parts, intake manifold, timing gears, timing gear chain or belt and cover, flywheel, harmonic balancer, valve covers, oil pan, oil pump, engine mounts, seals, and gaskets, water pump; also turbocharger and supercharger housings and internal parts, valves, seats, and gaskets.
Transmission - Case and all internal parts, torque converter, vacuum modulator, seals and gaskets and transmission mounts, also transfer case and all internal parts, seals and gaskets.
Front Wheel Drive - Final drive housing and all internal parts, axle shafts, constant velocity joints, front hub bearings, seals and
gaskets.
If you need further assistance please, don’t hesitate to contact me.
Michelle, Chevrolet Customer Service
__________________
Supposed to be the same for all 1993 through 2009 cars. I don't really see where the part falls in, unless it's an internal part of the head? Looks like the valves has to do with the turbo/supercharger?
Old Sep 1, 2012 | 07:15 PM
  #37
exninja's Avatar
According to this post: 2007 to 2009 model year GM 5yr/100k Powertrain Warranty camshaft actuator solenoid valve replacement is covered under the powertrain warranty
Old Sep 2, 2012 | 12:44 AM
  #38
FrossB's Avatar
Thread Killer
Aw damn. I wonder if the actuator on the cam is covered???
Old Sep 2, 2012 | 01:37 AM
  #39
exninja's Avatar
If this is the procedure:
J0824
Camshaft Position Actuator Replacement
P
Then yes.
Old Sep 19, 2012 | 01:42 AM
  #40
FrossB's Avatar
Thread Killer
Update!!!!
Took me long enough haha i have been super busy so it took awhile.
Anyway, what turned out to be the problem was my lack of knowledge. I recently rebuilt my engine myself and in doing that i wasn't aware that the camshaft actuator bolts (the ones that hold the cam gear to the cam) were "torque to yield" bolts, meaning they are one time use. So i used the old ones and what had happened is the intake bolt had backed its way out and the cam gear (actuator) was wobbly, thus causing an intermittent DTC. This probably isnt going to be a common problem for normal "simple bolt on" cobalts. More common would be the solenoid valve going bad...which that in itself isn't very common.
Been driving it for 3 days and no CEL has come on and the car runs better. Need to hook up the car with HPT to make sure everything is good.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
