p0300-302 codes
p0300-302 codes
i got the cylinder 1-2 misfire... car runns perfect still until the cel comes on .. then leans right out, done every test i can think of .... here is what i have done so far..
new maf/comp test/new coils/new plugs/vacuum/boost test/tested injectors individually.... running a dynamic comp test (while car is running test compression) i guess if im off by 2psi my valves are bent? anything else i should be looking at?
OrangeCoba
Sep 25, 2015 06:06 PM
