P2261 issues
Old Aug 23, 2015 | 10:53 PM
SPOOLING's Avatar
P2261 issues
So to keep it short I was getting the P2261 CEL. Had some turbo flutter and decided to change the BPV. Bought a Forge and installed it and I'm having the same issues.
It's installed correctly with the opening down, green spring. I'm still getting turbo flutter up until about 3k or so..after that it doesn't even blow off? Unless its just that quite...
I took it apart and it's fully lubed. I can also boost past 5LBS. I'm also still getting the p2261 CEL.
Thoughts, suggestions?
Old Aug 26, 2015 | 02:25 PM
SPOOLING's Avatar
So I took it for a ride today. At low boost I get turbo flutter but not at high boost. High boost its fine.
Should I try the yellow spring maybe? It seems most people have had issues though and stayed with the green.
Old Aug 26, 2015 | 03:40 PM
umrdyldo's Avatar
First thing to try is deleting the vacuum tank
PI: LNF- Intermittent DTC P2261 - Cobalt SS Network
Old Aug 27, 2015 | 02:19 AM
Sl0wbaltSS's Avatar
First thing, do the vaccum tank delete mod. Then be happy and do it the easy way.
Are you tuned at all?
Old Aug 27, 2015 | 02:53 AM
SPOOLING's Avatar
Yes Term2 tuned. Should I still try the tank delete mod? Is there any pics of the mod around?
Old Aug 27, 2015 | 10:50 AM
Sl0wbaltSS's Avatar
Yep do it.
https://www.cobaltss.net/forums/08-1...esting-315220/
So basically, take the line coming from your BPV and plug it in directly into the intake manifold nipple at the top and unplug the line that the little boost solenoid thing from the manifold, then unplug the line from the vacuum tank to the little boost solenoid thing and unplug the bottom one then get some vacuum live from the parts store and cover up the 2 loft over holes on the boost solenoid thing with the same piece of vacuum line.
Then you're done!
I had fluttering problems at wot and if I let off before 6k, now I don't have any!
Old Aug 27, 2015 | 01:52 PM
SPOOLING's Avatar
so basically just get about 6" of line and do this with the lines....
[IMG][/IMG]
Old Aug 27, 2015 | 10:29 PM
LNFwagonSS's Avatar
Or you could attempt to actually diagnose the problem if you have the tools. Use a mityvac vacuum bleeder or similar and apply 10-15 in.hg vaccum to each side of the tank to see if it holds. One of the hoses will be used to see if check valve still works and the other side is to determine if tank is intact and not cracked( you will need to plug opposite hose during this test).
Old Aug 27, 2015 | 11:42 PM
Sl0wbaltSS's Avatar
If he's tuned anything above Factory, GMS1, or a HPtuned factory tune or a HPtuned GMS1 tune you ARE going to have BPV issues. Just do the vacuum tank delete and it's fixed and the BPV opens all the way.
Also sp00ling that's my pic I'm css net famous!
Old Aug 28, 2015 | 07:35 PM
LNFwagonSS's Avatar
Weird, I've been tuned with trifecta and HPT without any BPV issues.
Old Aug 30, 2015 | 06:32 PM
reybalt's Avatar
P2261 issues
I have the same problem but my car is running lean too.
turbochargedss2012
Sep 20, 2023 12:17 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
