P300 p303
Old Apr 22, 2010 | 11:27 AM
SSturb's Avatar
P300 p303
Cylinder missfire, i have a trifecta tune so im weary about taking it up to the dealer. anyone have any suggestion? Or an easy do it yourself fix?
Old Apr 22, 2010 | 11:31 AM
BlackJackSS's Avatar
300 is random misfire in first 1000 revolutions. 303 is misfire on cyl 3. id check your spark plugs. or just get new ones. if that dont work you may have a bad coil or coil pack.
Old Apr 22, 2010 | 12:16 PM
jarhead's Avatar
Yep change plugs, Try the easy things first if that doesn't work move the coil pack from another cyl takes 2 min to do. See if problem follows coil pack Hope thats all it is and not something worse.
Old Apr 22, 2010 | 12:32 PM
Terminator2's Avatar
Switch the coil on cylinder 3 with one of the other cylinders see if the misfire follows the coil. If the misfire is still on cylinder 3 change the plug. Look for signs of oil. If the misfire still on clylinder 3 it is likely a hard parts issue.
Old Apr 25, 2010 | 03:11 PM
SSturb's Avatar
So i went to go get gas yesterday morning and after i filled up and started my bitch up. the CEL was gone and car runs and feels fine. So i guess what im asking is, is it possible to have had a bad batch of gas? And not worry about it? or should i still check out my plugs?
Old Apr 25, 2010 | 11:13 PM
army_greywolf's Avatar
You would be shocked what the feds say is "good" gas. I mean look at it this way, if gas from the distributor went into less than perfect storage tanks and it was already minimum specification for octane and water content, you get where I am going with this. Best bet is to ONLY get gas at stations that have a higher sales volume, are at the highest possible elevations in your area to hopefully have tanks above the water table yet below the frost line. Where I live this is important, Louisiana isn't really known as a "dry" heat. Not many even consider that.
c_m_shooter
Sep 27, 2015 04:40 PM
sS07NA
Feb 14, 2015 04:26 PM
GreenySC2
Feb 22, 2014 08:38 AM
bigjacksauto
Aug 21, 2013 04:38 AM
Stamina
Dec 1, 2009 09:22 AM
