Pacesetter Header Install Cost Issue??
Old Jan 27, 2012 | 04:58 PM
Dirtdevil77571's Avatar
Ok I went to go get quoted on a install for the pacesetter header I just received in the mail and the guy told me that they had to take the cat off install the header and tune the car afterwards. He told me the cat was going to stay off. 2 questions someone please help, he said after the Tune the check engine light will stay off with no cut because he said it will be running clean enough to avoid the light. Also one more thing he said it would be $1150.00 Dollars does this sound reasonable for the work he is doing?? 2 Questions here please. Thank you so much in advance.
Old Jan 27, 2012 | 05:06 PM
05Slowline's Avatar
1. You don't remove the cat you remove the flex pipe on whatever dp you have, stock or aftermarket. The pacesetter has a ball pivot that serves as the flex pipe.
2. If he tells you that your car won't throw a code catless he is a moron and should be working on model cars in his mothers basement instead.
3. A tune isn't necessary but you will reap the most benefit from the modification if you get it tuned.
4. 1,150 to install a header. LMFAO. Nuff said.
Old Jan 27, 2012 | 05:09 PM
07LSJ's Avatar
is that a typo??
Old Jan 27, 2012 | 05:10 PM
MastaShaKe_88's Avatar
Thats about all you really need to take from what he said... Me an my buddy swapped his Header an DP in like 3 hrs... tops... an thats with 2 trips to Advanced Auto parts down the street
Go somewhere else, everything dude said is rediculous...
oh an you posted in the wrong section
Old Jan 27, 2012 | 05:12 PM
Thats weird I just called him back and asked him if he was 100% sure it would not throw a code, I wonder why he would say that the shop is well known and they would have to make it not throw a code if it did, that would just be unethical.
Old Jan 27, 2012 | 05:13 PM
05Slowline's Avatar
If he's so certain that it won't throw a code he will probably use HPT to disable the code so it won't come up. What's unethical is that he isn't telling you that and you could get fined lots of $$$ if it was found out.
Old Jan 27, 2012 | 05:15 PM
Whining-devil's Avatar
yea you do not need a tune, like 1.5-2hrs install from a shop so like 160$ max.
Old Jan 27, 2012 | 05:16 PM
05Slowline's Avatar
Yea if you got the header installed and tuned I would say 450 MAX.
They will have to weld a flange to where they cut the flex pipe off, and some of the bolts are a complete bitch, so I'll give them that.
Old Jan 27, 2012 | 05:28 PM
Wow thank you so much sorry for the wrong area post, yeah i thought the price was steep does anyone know a shop that will do the work for me near houston tx because I have been quite a few places and they wont do it for some reason. Thanks in advance.
Old Jan 27, 2012 | 06:10 PM
tomj77's Avatar
header or manifold? cause we got no headers
Old Jan 27, 2012 | 06:21 PM
05Slowline's Avatar
Lol was just about to call you a ******* till I scrolled up and seen that masta called it also
Old Jan 27, 2012 | 06:36 PM
alerosaint's Avatar
I know right...i thought i was trippin for a minute
Turbo Johnny
Feb 21, 2019 09:41 AM
DocSvensk
Sep 27, 2015 02:24 PM
budah93
Sep 15, 2015 07:23 AM
