Please help people with trifecta
Old May 18, 2013 | 10:16 AM
RED08SSTC's Avatar
They changed how they do their tunes now I have to disable rear o2 sensor my self. What boxes do I uncheck to do that?
Old May 18, 2013 | 11:47 AM
WishI hadaNiceCar's Avatar
P0420 Low Catalyst Effic. Is the one i threw when i put the catless DP on.
Old May 18, 2013 | 11:51 AM
nobody2u's Avatar
I haven't updated my software since their last update. Can the program disable the cat warmup cycle now? Or do you still need to request that.
Old Jun 3, 2013 | 10:11 AM
joepackersrock's Avatar
Quick bump on this one, I just got trifecta tuned on my lnf. I have flashed the tune 3 times now with the box for p0420 unchecked, but it just keeps throwing the code. Is there something else I need to uncheck as well or some other kind of flash I need to do?
Old Jun 3, 2013 | 05:23 PM
jarhead's Avatar
No that is what you do exactly. I have done it on 2 cars in the last month. When you uncheck it you have to stay in the page not close ez flash and then go to the program vehicle right after you uncheck the p0420. If you are doing that po420 should not come back. I also always do a code scan and clear the po420 first also I don't think that matters though as when flashed it will be gone anyway.
Old Jun 10, 2013 | 01:47 AM
Bringing this up again...my car was apart for a few days so I didn't get a chance to run it. These are the exact steps im taking, what am I missing?
1. Open ezflash, connect interface cable, turn ignition to "on".
2. Under the program tab I go under "adjust tune settings" and click on "OBD2 DTCs and Readiness Monitors"
3. I then scroll down unselect "p0420 - catalyst system low efficiency". Then click "Ok".
4. One time I took the extra precaution of repeating steps 2-3 to make sure it hadn't reverted.
5. Under the program tab click "Program Vehicle" then select tune file and flash to vehicle.
I've done this twice now to change up the launch control setting, both times the launch control was changed just as it should have been, but after 3-4 ignition cycles the p0420 code pops back up. What gives?
Old Jun 10, 2013 | 02:02 AM
footballplaya3k's Avatar
I emailed Vince and he won't disable the cat warm-up, even for a track tune. Any way we can do this ourselves?
Old Jun 10, 2013 | 02:04 AM
Omnigear's Avatar
Hp tuners
Old Jun 10, 2013 | 09:46 AM
Hp tuners
Well until such a time that I have hp tuners I want this code to go away.
Old Jun 10, 2013 | 01:20 PM
tomj77's Avatar
Vince should stop being a nub and just do what the customer asks. It's really not his problem if something goes wrong if he warns the customer.
I respect his tuning but come on, give us some options
Old Jun 10, 2013 | 01:21 PM
Sox-Fan's Avatar
Got Brakes?
You're a U.S. liability lawyer?
Old Jun 10, 2013 | 03:56 PM
Old Jun 10, 2013 | 07:45 PM
tomj77's Avatar
Yes I am
Old Jun 10, 2013 | 07:55 PM
Omnigear's Avatar
thats what james do , dont he?
Old Jun 10, 2013 | 08:37 PM
m33pm33p's Avatar
You're the same exact person that would cry wolf if something went wrong because of the tune.
Don't like it get hp tuners or stfu.
There's options for our cars use them or go cry on a honda forum kthnxbye.
OP, only thing I can recommend since you took the right steps is to clear all your codes through ezflash, turn car off, disconnect battery/reconnect then reflash with o2 code deleted. Other wise *shrug*
Old Jun 10, 2013 | 08:42 PM
Macgyver2484's Avatar
Vince disabled the cat warmed for me. Idles real nice and low from a cold startup. Maybe you pissed him off or something? lol
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Builttss
Oct 4, 2015 10:21 AM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Adecker
Sep 28, 2015 10:57 AM
TurboWood
Sep 28, 2015 05:10 AM
