Possible Blow By?
I was going to change my water pump because my car was overheating. When I felt the the chain it was loose so i took the timing chain cover off, and the tensioner was what needed replaced. The big problem came when I discovered that everything in the engine reaked of gas. The intake, and charge pipe has what I would believe to be an excessive amount of oil in them. I'm thinking it is most likely blow by
. I am going to do a compression test when i get it all put back together. Is there anything else that might be causing those two issues together like that?
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
breds2k
19
Sep 21, 2015 10:24 AM
