Possible Blow By?
Old Feb 19, 2015 | 09:04 PM
BaltNasty's Avatar
I was going to change my water pump because my car was overheating. When I felt the the chain it was loose so i took the timing chain cover off, and the tensioner was what needed replaced. The big problem came when I discovered that everything in the engine reaked of gas. The intake, and charge pipe has what I would believe to be an excessive amount of oil in them. I'm thinking it is most likely blow by . I am going to do a compression test when i get it all put back together. Is there anything else that might be causing those two issues together like that?
Old Feb 19, 2015 | 09:07 PM
user 72239's Avatar
Could be a bad PCV, but the compression test will tell you for sure
Old Feb 19, 2015 | 09:49 PM
JapEatr's Avatar
South Central *********
Or bad turbo seals explain all of it
Old Feb 19, 2015 | 10:18 PM
kzak104's Avatar
everything smells like gas? could also be a leaking hpfp or running rich for some reason, what do you consider a lot of blowby.
Old Feb 19, 2015 | 10:21 PM
cleanxfe's Avatar
Im gonna guess leaking hpfp
Old Feb 19, 2015 | 10:23 PM
cleanxfe's Avatar
Sheeiitt beat me to it lol
Old Feb 20, 2015 | 01:16 PM
tomj77's Avatar
Don't know what u call excessive pick would be nice, but our cars need the Powell oil separator, not a catch can, those don't work. Timing chain will be a little loose when engine isn't running , the tensioner tensions when oil is pumping through it.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
breds2k
19
Sep 21, 2015 10:24 AM
