Proper caliper slide pin grease?
Im going to be doing my rear brakes shortly and want to know what kind of lubricant to use on the slide pins and what pads aren't going to repaint my wheels black, and maybe last 50k miles or so. Also what is a tried and true caliper tool?
I used a synthetic brake lubricant on the slide pins and on the back of the pad (optional) but the lube you use I don't think makes a big difference. I have Hawk HPS pads on the rear and they don't produce as much brake dust as I thought they would, so little of the braking power comes from the back that I don't you have to worry too much about the back brakes.
I bought the tool that supposedly works and it didn't lol so I just used needle nose pliers and some elbow grease and it worked just fine.
i need mine about a month ago, the pads i got( not by choice) were from napa auto parts. they actually work really well and there is zero dust. When you do go and look for pads make sure they are the right ones, they should also fit a sabb 04-08, had a hard time finding the right ones. I just used needle nose plyers and a hammer and a C clamp.
good luck
good luck
Thanks guys. I just wanted to make sure I used the right lube since I had been warned certain kinds of grease were not moisture resistant. Early next year gonna invest in new pads and turning all my rotors. No use in getting my local dealer to fix it since they had no idea what the LNF kit was. They would probably just look at my car and say it was normal for the rear brakes to wear out every 5k miles.
Do you put grease all over the pins?
What can you use to hold up your calipers while changing the pads/rotors? Will a wire hanger hold up alright?
Its personal preference, i use a clear silicone based lube.Do not use antiseize,it not meant to stand up to the heat of brakes it will turn into almost a glue over time and will cause the pins to sieze into the guides. You can go to any parts store an buy the cube tool. It is a universal caliper tool that will spin the piston back in using a ratchet an small extension,very inexpensive.Unless you wanna drop the big bucks for the master set of caliper retracting tools.
Amazon.com: Permatex 24125 Ceramic Extreme Brake Lubricant - 8 oz.: Automotive: Reviews, Prices & more
That is the only brake lube these cars should use because they CAN get far too hot for normal lube. Not saying they will for all the naysayers but because you can basically burn off a lesser lube this is insurance you need.
1 Post
There also the smaller size: Permatex 24124 Ceramic Extreme Brake Lubricant
Permatex 24124 Ceramic Extreme Brake Lubricant - 2.0 oz [small size]
Permatex 24125 Ceramic Extreme Brake Lubricant - 8.0 oz [large size]
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
