Proper caliper slide pin grease?
Old 12-17-2009, 11:22 PM
1Rare4Door's Avatar
Im going to be doing my rear brakes shortly and want to know what kind of lubricant to use on the slide pins and what pads aren't going to repaint my wheels black, and maybe last 50k miles or so. Also what is a tried and true caliper tool?
Old 12-17-2009, 11:46 PM
tom.g's Avatar
I used a synthetic brake lubricant on the slide pins and on the back of the pad (optional) but the lube you use I don't think makes a big difference. I have Hawk HPS pads on the rear and they don't produce as much brake dust as I thought they would, so little of the braking power comes from the back that I don't you have to worry too much about the back brakes.
I bought the tool that supposedly works and it didn't lol so I just used needle nose pliers and some elbow grease and it worked just fine.
Old 12-18-2009, 02:23 AM
greenlantern459's Avatar
i need mine about a month ago, the pads i got( not by choice) were from napa auto parts. they actually work really well and there is zero dust. When you do go and look for pads make sure they are the right ones, they should also fit a sabb 04-08, had a hard time finding the right ones. I just used needle nose plyers and a hammer and a C clamp.
good luck
Old 12-18-2009, 08:28 AM
Maven's Avatar
This is all I use lately and I highly recommend it. (works as a good antiseize too)
Old 12-18-2009, 08:29 AM
glhs379's Avatar
my rear hawks are also awsome, no brake dust
i greased my pins with reg wheel bearing high temp grease
they were dry as a bone
Old 12-18-2009, 11:10 AM
Gimpster's Avatar
Do not use wheel bearing grease, use what Maven posted. Costs a few bucks, but its the right stuff... won't disappear on you like wheel bearing grease.
Old 12-20-2009, 10:44 PM
1Rare4Door's Avatar
Thanks guys. I just wanted to make sure I used the right lube since I had been warned certain kinds of grease were not moisture resistant. Early next year gonna invest in new pads and turning all my rotors. No use in getting my local dealer to fix it since they had no idea what the LNF kit was. They would probably just look at my car and say it was normal for the rear brakes to wear out every 5k miles.
Old 12-21-2009, 03:57 PM
julius41282's Avatar
Do you put grease all over the pins?
What can you use to hold up your calipers while changing the pads/rotors? Will a wire hanger hold up alright?
Old 11-15-2010, 07:52 AM
vahdyx's Avatar
can someone explain how to do this for the less mechanically inclined
Old 11-15-2010, 04:02 PM
Willis08tc's Avatar
Its personal preference, i use a clear silicone based lube.Do not use antiseize,it not meant to stand up to the heat of brakes it will turn into almost a glue over time and will cause the pins to sieze into the guides. You can go to any parts store an buy the cube tool. It is a universal caliper tool that will spin the piston back in using a ratchet an small extension,very inexpensive.Unless you wanna drop the big bucks for the master set of caliper retracting tools.
Old 11-15-2010, 04:33 PM
09BlueBaltSS's Avatar
Cant see the pic. Got a link?
Old 11-15-2010, 07:21 PM
army_greywolf's Avatar
Amazon.com: Permatex 24125 Ceramic Extreme Brake Lubricant - 8 oz.: Automotive: Reviews, Prices & more
That is the only brake lube these cars should use because they CAN get far too hot for normal lube. Not saying they will for all the naysayers but because you can basically burn off a lesser lube this is insurance you need.
Old 11-17-2010, 02:30 AM
gone_in_10_sec's Avatar
There also the smaller size: Permatex 24124 Ceramic Extreme Brake Lubricant
Permatex 24124 Ceramic Extreme Brake Lubricant - 2.0 oz [small size]
Permatex 24125 Ceramic Extreme Brake Lubricant - 8.0 oz [large size]
biniecki
10-25-2015 02:23 PM
dennis69
10-20-2015 07:39 AM
HEATON
10-16-2015 07:21 PM
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
Quick Reply: Proper caliper slide pin grease?
