pulling motor?
Old Apr 1, 2010 | 09:50 PM
Black_Turbo_SS's Avatar
pulling motor?
does anyone know of anyone who has pulled an LNF from the top rather than dropping in from the bottom. does anyone know how hard that would be. Because i have to swap my motor and i dont have access to a lift.
Old Apr 1, 2010 | 09:53 PM
slowswap's Avatar
I believe you can drop it out the bottom without a lift.
Old Apr 1, 2010 | 09:55 PM
how so if the car is on jack stands?
Old Apr 1, 2010 | 09:57 PM
slowswap's Avatar
I believe ralliartist did it. Can't remember.
Old Apr 1, 2010 | 10:01 PM
hmm it would be nice to see pics so i know what im getting into..
Old Apr 1, 2010 | 10:03 PM
EcoTecDriver's Avatar
just remove the hood, and pull it.
Old Apr 1, 2010 | 10:06 PM
slowswap's Avatar
How do you clear the transmission output shaft? Or do you drop the transmission first?
yea i figured that much if i had to pull it, it just looks like a tight squeeze. i was just wondering if its not to hard to pull it
Old Apr 1, 2010 | 10:07 PM
PRND3L's Avatar
If you leave the tranny attached, i think you have to go from the bottom. Once you take the intake and the hood off, you should be able to tell.
Old Apr 1, 2010 | 10:11 PM
madmark's Avatar
you can leave the trans in and pull it, just everything on the passenger side has to be removed (harmonic balancer ect....) its still no fun but it does have enough space to pull it that way
Old Apr 1, 2010 | 10:13 PM
slowswap's Avatar
At that point I'd drop tranny out bottom then pull motor out the top....
Old Apr 2, 2010 | 12:54 AM
Boosted_Cobalt09's Avatar
id just go out the bottom. its a lot easier.
Old Apr 2, 2010 | 12:59 AM
YzRider452's Avatar
Agreed, but its still a pain in the dick...
Old Apr 2, 2010 | 01:06 AM
any time you pull a motor its a pain in the ass weather its out the top or bottom......god i miss carbureators lol. unbolt some misc here and there it and out the top it comes.
Old Apr 2, 2010 | 01:10 AM
Wolf117's Avatar
i pulled mine and dropped it out the bottom, it was all in one piece pretty much, i got a dolley from harbor freight for like 20$. set the oil pan on the dolley, and jacked up the car as high as i can and it rolled out
Old Apr 2, 2010 | 01:13 AM
ItalianJoe1's Avatar
I've done two motor swaps in my driveway, and a 3rd one tomorrow. It's not bad to pull it from the bottom on the ground, just put the car way up on stands and lower it down with a hoist. I helped ralli through it the first time he did it. Lemme know, i'll give advice if needed.
Old Apr 2, 2010 | 01:20 AM
how high do u think the car needs to be on stands?
Old Apr 2, 2010 | 01:19 PM
its really not bad, i cant speak for the cobalt but i pulled a v6 out of a infinti just buy reomoving the hood and other items, kept a jack under the tranny and pulled the motor right out, with only 1inch of play to work with lol
its really not bad, i cant speak for the cobalt but i pulled a v6 out of a infinti just buy removing the hood and other items, kept a jack under the tranny and pulled the motor right out, with only 1inch of play to work with lol
Last edited by EcoTecDriver; Apr 2, 2010 at 01:19 PM. Reason: Automerged Doublepost
Old Apr 2, 2010 | 01:49 PM
High enough to get the motor under the pass side frame rail. There's a big cutout on that side that just so happens to be about the size of a valve cover
I'd say, about 3 feet of air under the front lip should do the trick. You can always jack the car up a little more once the motor is on the ground to get the clearance.
Solaris99
28
Mar 15, 2017 01:22 PM
Oct 20, 2015 09:56 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
