Rattle now after installing badmab dp
Old Dec 25, 2011 | 06:43 PM
T CUPP's Avatar
i just installed my badmab catless dp. I also added the defouler and i didnt know if i used the nut and washer that came with it. So i just left it on there and installed it... Now the defouler is in a position where it hits the heat shield causing it to rattle. Will someone please explain how to use the nut to position the defouler in a position where it wont rattle and also be able to have enough cord for the sensor to reach the defouler
Old Dec 25, 2011 | 06:45 PM
TommyP's Avatar
AWD > FWD
I had to ditch the washer at least iirc in order to make sure it didnt hit the heat shielding
Old Dec 25, 2011 | 08:40 PM
T CUPP's Avatar
iirc? did you use the nut?
Old Dec 25, 2011 | 09:34 PM
TommyP's Avatar
AWD > FWD
IIRC is if I remember correctly. I know it was too long with everything on. I don't think I used the nut if the defouler is able to be spun on without the nut do so, it will gain you an extra 1/4"
Old Dec 25, 2011 | 11:48 PM
T CUPP's Avatar
Okay thanks for the info
Old Dec 25, 2011 | 11:55 PM
Frogstofall's Avatar
Did you get the Vibrant defouler or a generic Autozone one (HELP brand)?
Old Dec 26, 2011 | 01:56 AM
AndrewSS/TC's Avatar
Mine rattles with a defouler I need to fix it, I have the Vibrant angled defouler from Modern Performance
Old Dec 26, 2011 | 02:41 AM
FasterIsBetter's Avatar
It also doesn't hurt to bend the heatshield a little I did that when I had my badmab without the defouler because the wires would rub. You should be able to just push on it with a finger or your hand.
Old Dec 26, 2011 | 09:36 AM
Prestige_Worldwide's Avatar
Mine rattles a bit but only when it's cold, I might climb under and see if it's hitting or if it's just the vibration.
Old Dec 26, 2011 | 10:23 AM
Boosted4's Avatar
I had to bend my heatshield a little bit when I installed my dp as well.
Old Dec 26, 2011 | 11:23 AM
T CUPP's Avatar
i have the vibrant
Old Dec 26, 2011 | 11:44 AM
bspeed's Avatar
same , just bend the heat shield
Old Dec 27, 2011 | 02:50 AM
Originally Posted by T CUPP
i have the vibrant
Like they said, just bend the heat shield. Mine has the washer on it still too. It's situated in a way that the defouler points to the front of the car. Works pretty well.
Old Jan 1, 2012 | 07:40 PM
T CUPP's Avatar
i know to bend the heat shield.
Frogstofall did you use the nut also?
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
jimbofug007
Oct 2, 2015 12:06 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
