Rebuild With Gen 3 Block
Old Oct 15, 2013 | 10:37 PM
cmiller8006's Avatar
So after I got the build completed and started to drive the car I quickly noticed that it was loosing coolant, seemed as if my ZZP motor had the famed porous block or cracked block. So I got in contact with Matt at ZZP and we decided I should go with the gen 3 block do to the sand casting and the cast in cylinder sleeves. Now there has been some confusion on whether the 2.0 has sprayed in nikasil liners or cast in place liners so I called and talked with GM as well as finding some of the r and d sheets on the ldk an20 block. it indeed has cast in place liners. Any way I ended up sticking to the stock block, no girdle as it should be plenty strong and support around 700 whp I would think. I also left the block with the balance shafts and what not, so I put the mechanical pump back in and got rid of the electric pump. So this build is still on a 6262 pte turbo, full ZZP everything, ZZP 6 speed swap. So here are a few pics.
Old Oct 15, 2013 | 10:46 PM
slapbetcommissioner's Avatar
That gen 3 block just looks so much more confidence inspiring. Can't wait to see the final results here!
Old Oct 15, 2013 | 10:57 PM
EXsoccer1921's Avatar
That's a really cool last picture.
Old Oct 16, 2013 | 12:45 AM
Yea this block is just sexy all Around.
Old Oct 16, 2013 | 02:28 AM
Fastgti69's Avatar
Damn, after all that still had to get a new block!! Labor cost must be horrible man. Do you do the work yourself? I'm still always into your builds man. It is a work of art and i can't wait till you make some new passes with that.
Old Oct 16, 2013 | 10:45 AM
I do everything but the machine work, since this was a new block the cylinders needed opened up a smidge, mains got align honed since they were a little tight and the block was good to go.
Old Oct 16, 2013 | 10:57 AM
noorj's Avatar
This looks awesome, I will be using a gen 3 block with my build also.
How much did you have them take of when then honed it?
Old Oct 16, 2013 | 11:54 AM
You can't go off what I had to have taken out. I have my bores set up at 4 thou clearance for what I intend to do. 3.5 thousandths should be sufficient for most people. I wouldn't go any less then that. Wiseco recommends 3 but when I actually called the guy said he thought for 20+ psi and 500+ hp it was to tight. The bores stock were very round which was awesome but they didn't even have to take out .5 thou across the board.
Old Oct 16, 2013 | 12:20 PM
noorj's Avatar
Oh I know I was just curious, trying to get a feel for what everyone else does
Old Oct 16, 2013 | 12:25 PM
I see, if you are looking to go 500+ I would do 4 thousandths. On the rings I did the spec sheet and added a little more. I believe .020 on the top and .022 second
Old Oct 16, 2013 | 12:26 PM
574's Avatar
574
Seeing threads like this makes me want to do bad things. mmmm that gen 3
Old Oct 16, 2013 | 12:34 PM
Me doing this makes me wanna do really bad things lol. Like a rwd car with twins lol.
Old Oct 16, 2013 | 01:33 PM
Fastgti69's Avatar
That's why I got a 335
Old Oct 16, 2013 | 01:41 PM
I want a v8 tho lol.
Old Oct 16, 2013 | 02:12 PM
Fastgti69's Avatar
LOL, V8TT. I'd kill myself in one of those.
Old Oct 16, 2013 | 03:01 PM
FasterIsBetter's Avatar
Lol, hence why I went to a new coyote 5.0. Hoping to have the twin kit put on this winter with a t56 trans. Found out if I spent the amount of money I did on the cobalt on my mustang I'd be sitting right around 1000whp and high to mid 8 second 1/4 mile times lol.
Old Oct 16, 2013 | 03:11 PM
InfraRedline's Avatar
Looks awesome man. Some more Gen 3 goodness! Mine is sitting patiently ready to go in my car Girdled 2.1 though.
Old Oct 16, 2013 | 03:25 PM
Nfamous60's Avatar
Lmao if you do a rwd with twins sell me that motor
Old Oct 16, 2013 | 03:59 PM
You wanna buy it? I will sell it with the granny and everything lol.
Old Oct 16, 2013 | 04:09 PM
574's Avatar
574
I want to buy threes granny
Old Oct 16, 2013 | 04:32 PM
Tranny! Damn I phone
Old Oct 16, 2013 | 04:38 PM
I want the trans...on the cheap! lol
Old Oct 16, 2013 | 04:39 PM
Oh so you were selling grannies, now trannies? Idk if he wants a sexually confused mail order bride....lmao
Old Oct 16, 2013 | 05:01 PM
raver0789's Avatar
No teeth to get in the way didn't ya know?
Old Oct 16, 2013 | 05:42 PM
With the grannies you only got one thing, with a tranny you got a couple different options you know, if your into that kinda thing hahah. I am not.
