View Poll Results: If ZZP R&D'd a new rear brake system for LNF would you support?
Hell yeah 100%, I'll buy day one!
24.22%
Probably, depending on price
51.56%
Probably not, I don't have rear brake issues
8.59%
Maybe, but there's other things I want to do with my money!
4.69%
I'm selling the car so it doesn't matter
2.34%
Nope!
5.47%
Other
3.13%
Voters: 128. You may not vote on this poll
Request for ZZP to make new LNF Rear Brake system!
Old Apr 29, 2013 | 09:20 AM
  #76
C_A_D88's Avatar
so I should have a prototype up and running towards the end of May....70 people are interested, many want to see price, so I will let you know. Full ebrake etc will be a feature of this set up with a Brembo rear caliper, NOT the LNF Brembo front caliper though. Brake balance is important....
May need to save up but would def buy
Old Apr 29, 2013 | 09:24 AM
  #77
Powell Race Parts's Avatar
First customer. I will mock it up on a spare rear beam but it could be easier to swap out the beam are there mods to the beam for your air ride? You know where I live it will take a couple if weeks for the e brake assemblies and rights to get here so start saving. It may not cost that much. Depends on the Brembo caliper
Old Apr 29, 2013 | 09:56 AM
  #78
C_A_D88's Avatar
Yea I had to cut off the spring retainer nipples but they could b welded back on
Old Apr 29, 2013 | 11:15 AM
  #79
Kyle09TC's Avatar
I'm local as well and kinda interested pending the setup and price. Will it use the stock rotor size for the rear?
Old Apr 29, 2013 | 12:45 PM
  #80
roughly the same diameter didnt I post a picture? This is the rotor. The caliper of course will be different and I am not sure how far up I will clock the caliper. Probably closer to axle centerline
Old Apr 29, 2013 | 12:58 PM
  #81
colodude18's Avatar
Sub'd.
Funny how the guy that started this thread no longer owns his Cobalt
But thanks for getting this started Mike!!
Old Apr 29, 2013 | 01:48 PM
  #82
dont care about the nipples it will be easier to prep a drum brake beam for you, BUT you cant use a bolt on rear bar, right? better text me tonight busy doing shipping and fab stuff
Old Apr 29, 2013 | 03:06 PM
  #83
C_A_D88's Avatar
Yes that's correct I can't use a bolt in rear sway bar
Old Apr 29, 2013 | 03:10 PM
  #84
C_A_D88's Avatar
Will text u later john
Old Apr 29, 2013 | 06:01 PM
  #85
vahdyx's Avatar
Sub'd.
haha I know. I'm fickle!
I did go through 5 different tunes and tuners, 4 lowering springs, 2 intakes and 2 Cobalts lol.
At least I can leave something behind that'll contribute to the good of the SS's.
Old Aug 22, 2013 | 08:54 PM
  #86
willdrew's Avatar
saw something on facebook recently. this might be in the works!
Old Aug 22, 2013 | 10:01 PM
  #87
slvrred-'s Avatar
that was a front setup you saw on facebook today. that car is there LSJ car and it had factory brakes with upgraded pads and rotors. Looks like the took calipers off a Camaro and were able to run a huge front rotor. 14.5 I believe they said
Old Aug 22, 2013 | 10:07 PM
  #88
Well at least I figured out part of the old rear brake problem you had still would love to see a brembo caliper back there even if it was a simple single piston.
Old Aug 22, 2013 | 10:31 PM
  #89
its so much effort but it goes like this: cut off ears for caliper on rear beam. or install drum brake beam. install my adaptor plates, install 9.5 saab rear brake assembly rotors ebrake in rotor hat, and a brembo rear caliper.
done.
1750.0
oh and you supply the drum rear beam or cutyour ears off i am not shipping beams.
you asked. I answered.
pictures. ignore the caliper and rotor, this illustrates the bracket
this is the rotor, with a drum ebrake in the rotor, ignore the slider caliper
Old Aug 22, 2013 | 10:34 PM
  #90
Def is a lot of work, nice to know someone has a solution, again john produces the solutions for ppl that ask the questions
Old Aug 23, 2013 | 09:41 PM
  #91
slvrred-'s Avatar
done.
1750.0
Hey john, what calipers can be used in this setup? you say to ignore the slider.....so which caliper do we use?
Old Aug 23, 2013 | 09:57 PM
  #92
Brembo. not cheep. single piston monobloc It is important to maintain the same fluid volumes as the stock caliper otherwise you will risk running out of brake pedal stroke as the pads wear.
Just read your email on my phone re send i cant see pictures for some reason iphone choked on them.
Old Aug 24, 2013 | 09:40 AM
  #93
C_A_D88's Avatar
So the 1750 includes what?
Old Aug 24, 2013 | 10:00 AM
  #94
Wert842's Avatar
Holy hell look at those meats!
Sent from my Samsung Galaxy S4 using CobaltSS
Old Aug 24, 2013 | 03:06 PM
  #95
C_A_D88's Avatar
John what calipers r u using? Don't need to tell me straight up but can we get a pic?
Old Aug 24, 2013 | 07:49 PM
  #96
single piston brembo. this will be an october project i think.
Old Aug 24, 2013 | 08:10 PM
  #97
C_A_D88's Avatar
Good will give me a chance to save up now that I have a price lol
Need rims first tho
Old Aug 27, 2013 | 09:47 AM
  #98
andrewcarr1993's Avatar
Awesome, I'm swapping to brembo front's soon while doing a 5 lug swap. Now I've just got to save up for this and I won't even have to worry about having a drum rear beam.
Old Aug 27, 2013 | 09:56 AM
  #99
troof. other than brake balance drum rear beams are an advantage.
Old Sep 10, 2013 | 12:17 AM
  #100
So does this kit ship or we come to you? I'd be interested in making the trip seeing as it's not too far for me (outside of Buffalo, NY).
