RIP LNF tranny
Hey now. I went all out with my zfr and danced with fire as long as possible. I beat the **** out of my lnf stock trans until it shattered. I knew it was just a ticking time bomb and it was gonna go. I like breaking things.
Sent from my Samsung Galaxy S4 using CobaltSS
I'll probably do the same thing in the future. My stock trans doesn't have LSD so I'm thinking I should just let it in until it goes even if I'm on a bigger turbo.
Come to think of it, if it broke at my altitude after 12 laps, it probably wouldn't have lasted beyond lap 2 had I been at sea level...
"I want some fun with it" - translation: say farewell to the transmission.
I was running on e47 and 26psi and having LOTS of fun when this **** happened
fmsr? waiting for Rudy to tell what the upgrades are for $999 additional.
we rebuild and sell a lot of transmissions. funnily enough the first shop EVER to rebuild an F35 for Cobalt in fall 2004. Before Cobalt went on sale. Just to point out that we do have a clue how to fix them.
I already have and had the ky 3+ clutch on my car for about 2 years already. I have had no issues.
not sure ZZP do any trans other than their fine f40 upgrade too many issues with silly installs from purchasers?
Zzp does only offer the f40 hence why I said "if you have the money" I also never said you(Powell) don't know about cobalt transmissions, I'm sure you do. A transmission from you would be another option.
Don't know what he means by "upgraded" but here's a list.
LEVEL II: (Heavily modified FMSR transmission) Rated 550+ lbft/TQ!!!!! - Highest rated F35 transmission in the market!!
Cryogenically & Thermal heat treated transmission components
FMSR Stage II preload specs
Shot peen Trans case
Shot peen Trans components [selected]
Upgraded Case bolts
Upgraded Trans case dowel pins [Used only with our FMSR GEN II OR GEN III Blocks]
Upgraded Crush Sleeve
Upgraded Bearings
Upgraded Case bolts
Upgraded Bearings
Upgraded Case bolts
Upgraded Bearings
Upgraded Case bolts
Upgraded Bearings
RIM finishing gears is very popular we get it done a lot on Corvettes, it reduces friction and may well incrementally improve surface strength but the only way to stop the third gear breaking in my opinion is to make a new gear. Those are available at Emco at about 1000.00 per set by three sets of gears (close ratio 2,3,4) at a time.
So for the OP if I was to do this, the transmission would be up to about 7,000 dollars with no real way of establishing a revised torque capacity, and way more $ than the FMSR trans. But it would not have the upgraded bearings sleeve bolts and dowel pins. I should mention that the shift rails, the shift forks the synchros which are normally a replacement item in many transmissions never seem to fail in the F35. The second gear blocker ring fails its high strength steel.... Also I would not willingly build one to this spec as the price is retarded and I dont want to be on the other end of the phone when it gets broken....lol
