runing fine? rich? lean? HELP!
Old Apr 23, 2009 | 05:28 PM
cardelino18's Avatar
Question runing fine? rich? lean? HELP!
my car threw the check engine light and its farting like a mother F****.... i have trifecta tune, dejon intake, and custom cat bak exhaust... 3'.... wat is it?
Old Apr 23, 2009 | 05:43 PM
RYRO14's Avatar
check the recirculating hose. I had the same problem of running lean and it was because the recirculating hose wasnt on tight enough.
Old Apr 23, 2009 | 05:56 PM
TrevMo's Avatar
Take it in to a GM dealership and have them scan your ECU with a Tech II...I'm sure they can tell you why you are having problems...
Old Apr 24, 2009 | 01:04 AM
supermantxz24's Avatar
was it during a no lift shift?
Old Apr 24, 2009 | 09:37 AM
naw....
Old Apr 24, 2009 | 09:47 AM
randizzle's Avatar
i'd take it to one of the auto parts stores that will scan for free and see what you come up with. could be something simple.
Old Apr 24, 2009 | 10:01 AM
Terminator2's Avatar
What he said. Find out what the code is then you can look for the issue. Breather line could be loose, map sensor problem maybe. Chargepipe or IC leak is possible. Get the code read then let us know which code it is.
turbochargedss2012
Sep 20, 2023 12:17 PM
HEATON
Oct 16, 2015 07:21 PM
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Sep 28, 2015 02:46 PM
DocSvensk
Sep 27, 2015 02:24 PM
