Running lean after seafoam?
So last weekend i decided to seafoam my car. car was running fine prior to that. ever since, I have been throwing 2 lean codes (p2177) and a Manifold absolute pressure (map) system performance code (p0106). I changed out my O2 sensor thinking it might be bad and causing my A/F ratio to be off, and i get really bad miss firing while at WOT. Any ideas?
Loosened up some **** and fried your MAP manifold sensor? I just had some p0106 codes, and it was stuttering under low throttle, and running with 50% boost... changed out sensor and voila! back to normal
Also when i replaced the O2 there was a some liquid in there (looked and smelt like a mixture of carbon and gas) I have a defouler from MPX, is this normal to have that? I am assuming not.
Cleaned what residual liquid I could from the defouler and seems to run better but still miss fires at WOT. Cel is gone also. I think I possibly put too much in through the vacuum line too fast and didnt burn all of it.
replaced spark plugs, made it better, but missfires at wot, dont know if youve fixed it by now, but imma go with you gapping the plugs wrong, and they were fowled after the seafoam. Play with your gap, start around 35, and go down if need be, bet it will fix it.
On an unrelated note, AZ520SS/TC, where in WA are you?
Silverdale (just south of Bremerton). I figured it out, wasn't the plugs or map, it was from putting too much seafoam in at one time and causing some not to burn and coating my O2. I cleaned the defouler and replaced the O2, and she runs fine now. So a heads up for first timers putting it in through the vacuum line, GO SLOW. Lol.
