Running to lean at idle
Old Apr 22, 2009 | 02:29 PM
RYRO14's Avatar
Threw a CEL on a Trifecta tune, went to Advanced Auto Parts and the code sayed "running to lean at idle speed", the code didnt show up after it was cleared and I just installed the Hahn CAI the day before. What should I do?
Old Apr 22, 2009 | 02:36 PM
glhs379's Avatar
i guess this is a good reason to stay with one company
Old Apr 22, 2009 | 02:42 PM
SSpdDmon's Avatar
I wonder if that hose just behind the MAF (with the odd connector on it) is leaking air past. Unmetered air = lean.
Old Apr 22, 2009 | 02:53 PM
RYRO14's Avatar
The recirculating hose?
Old Apr 22, 2009 | 03:03 PM
Terminator2's Avatar
You got it right there. It is most likely a post MAF leak.
The vent hose from the valve cover that attaches to the intake nipple. It can come loose and leak sometimes.
Last edited by Terminator2; Apr 22, 2009 at 03:03 PM. Reason: Automerged Doublepost
Old Apr 22, 2009 | 04:29 PM
agent007kimball's Avatar
Seems like anything other then the stock intake causes unhealthy A/F ratios....the primary reason I am keeping to the stock one.
Old Apr 22, 2009 | 04:33 PM
elecblue06's Avatar
that and well your car hauls ballz lol
but yea like others said .. it's probably a post maf leak.. boost leaks and such tend to usually case that on FI setups any unmetered air messes things up
My A/F are perfect no MAF retuning was necessary. I had to replace the stainless breather hose with a rubber one to get it to seal though. Car dies off a lot more with the stock intake on there. Even with a drop on filter the stock intake it has a couple points where it necks down to less than 2.5."
Old Apr 22, 2009 | 04:39 PM
SSpdDmon's Avatar
Which is why I'm curious to see what the CIA intake and the new GM Stage 1 intake is going to look like.
Old Apr 22, 2009 | 08:35 PM
red2001ss's Avatar
The Code wasn't numbered P2187 by chance, was it? Mine throws that code now and then, usually after a road trip. Doesn't throw the light though when it pops up, on mine anyway. It does however limit boost to like 6-7psi when that code is on mine. I routinely look at the codes on my Dashhawk everytime I'm in the car. Didn't notice this till the Hahn CAI, IC and Charge Pipes were put on. Car runs fine and full boost after I clear the code.
Old Apr 23, 2009 | 02:57 PM
JPizzle's Avatar
His car was boosting approximately what stock it would (15-17), but I don't know what the P code was...
Old Apr 23, 2009 | 07:49 PM
FakeWhiteMan's Avatar
Mine threw that code, there was too much air getting in through my breather...\
it would only boost 5-7 psi
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
