Sea foam v bg44k
Sea foam v bg44k
I'm just wondering how Seafoam compairs to bg 44k. Why the need to change out the oil after seafoam while with bg you are fine to keep on going, they both seem to do the same thing?
U can keep the seafoam in the oil as long as u put it in when u change ur oil, should not put it in old oil and keep it there for to long, will liquify gunk and if u turn ur engine off the gunk may become solid again in places u don't want it to. When u put it in new oil it will prevent gunk from forming to begin with
44k goes in the tank.... It's a fuel cleaner. You need to get the upper intake cleaner or the direct injection cleaner kit. Also if you want a fuel additive look at the moa it is seriously the best stuff I have ever seen. Any tech will tell u bg products work. Moc and wenz and seafoam suck compare to bg
beerbaron105
Sep 30, 2005 03:37 PM
