Slow Tach?
Slow Tach?
Sorry if it's a repost.
Is everyones tach as slow as mine? Shifting 1-2 at WOT is tricky at times because the tach is so slow that you need to shift at 6400 on the tach when you are actually shifting at 6800 according to the scan. The easy solution is to raise the rev limiter to keep from hitting fuel cut, but I just wish it was more accurate.
