smoking after boost?
Old Jul 29, 2012 | 09:32 PM
klutch814's Avatar
im a 2.2 turbo. did some cleaning up under the engine today and cut my pcv valve hose to short so now it has a kink. could this cause my car to smoke after boost and sometimes at idle? or is it more serious? was planning to rebuild very soon but its a DD and the only car i have. the smoke appears to be whiteish greyish? i cant really tell from my mirrors.
i also have a small leak in my feed line but that is already ordered.
Old Jul 29, 2012 | 11:03 PM
klutch814's Avatar
anyone?
Old Jul 30, 2012 | 12:59 AM
Zander916's Avatar
Since no one else replied. I'm sure others are more knowledgeable but I'll give my input.
You should get that fixed asap. (The PCV hose) Chances are that pressure is building up that would otherwise be drawn out that hose. Consequently it's seeking another path to push out and can take oil with it. The smoke you are seeing is likely oil being burned which can create other costly issues such as fouling your plugs or O2 sensor.
Just in case though, since you said it might look whitish. Check your oil for signs of coolant. Might look like dirty mayo.
Old Jul 31, 2012 | 04:54 PM
gone_in_10_sec's Avatar
2x^^^ fix that kink!! you might be sucking in oil or coolant in the combustion chamber, which is causing the smoke..
and if it is coolant in the oil [milkly look], go the dealership and have them check for a blown head gasket or crack cyl sleeves..
Old Jul 31, 2012 | 08:42 PM
justinb's Avatar
White smoke with a sweet smell to it generally means coolant. I'd be worried about a blown head gasket or something else major like a cracked block. Make sure to get that looked at. You might consider a compression test on your own to see if the gasket is still intact.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
