sounds like a wrx???
any possibilites?
could the front 02 make this thing sound like a damn subie? i put my catless dp on with a muffler delete and car sounded good, i left a red light and and some hard dick in a gt decided he wnated to go, matted it in first gear regular shifted to 2nd and it poped real loud didnt think twice well the cel poped on and it threw a p13e code cleared the code and it came off and on 3 or 4 more times well long story short after it poped it sounds like a wrx checked the dp gasket and all the obvious things and caint figue out any thing. hasent lost any powa so i dunno any clues?
cliff notes
aem cai with a k&n filter
zzp catless dp
superchips tune (for now)
cliff notes
zzp catless dp
any possibilites?
cliff notes
zzp catless dp
cliff notes
zzp catless dp
does the car feel like it has no power?
and what kind of balt do u have?
Last edited by revolution607@yahoo.; Jan 19, 2010 at 07:54 PM. Reason: Automerged Doublepost
I have a 09 TC, and I will say even with stock exhaust, it does have a slight flutter to it...reminiscent of a WRX but definitely not to the same degree. Maybe with your exhaust mods it's amplified that.
Maybe get us an exhaust clip?
Sounds like you got in it a bit before your oil was at running temp and you started to misfire. Rather then just clearing the code you should've checked it.
I've noticed lately that my car sounds kind of like a Subaru at idle. It's just something I've noticed though, all my friends say it sounds the same as it has all winter.
Does it sound like its coming from the turbo area? With the hood open and the car on listen back near the turbo. Is it just as loud there as under the car? The downpipe still bolted tight to the turbo?
Possible that the wastegate is jacked up
ill check it wasent there a post were the turbo manifold cracked?
yes everytings tight no black exhaust dust any were under the car
at first i thought mabey the flex pipe cracked but didnt see anyting
I once did a NLS while cold and started missfiring like crazy. Lost all boost and power and It sounded like one of the cylinders werent firing at all (subbie sound). Should have let the car rest for a minute or two, then shut the car down and restarted it. The subbie noise should then go away. Since your tuned, I wonder if the safety mode is removed?
any possibilites?
cliff notes
zzp catless dp
cliff notes
zzp catless dp
it wasent cold i had been driving for about a hour an half in 70 degree weather,
update this morning started it up it ws around 32-34 degrees out let it run for 5-6 mins left home going to work car sounded fine un till the rpms get higher thants when u hear it, at idle it sounds fine i dunno i tried callin zzp for some insite and havent heard anyting thing from them so i fighured i would pick the brains on here
it happend with the pos aem filter on it since i switch filters it runs better
to answer the question no im picking up the hp set up bt the end of the month and hopefully t will be solved
DANRICKARD
Oct 1, 2015 12:08 AM
